Results 1 to 15 of 17
Thread: How do you hook up two vcr's?
    Pa.'s Highest City
    8,058
    Question How do you hook up two vcr's?
    If trying to record a vhs tape using two vcr's and I cannot for the life of me rememebr how to do it. The one vcr is built right into the tv.
    I have a three pronged wire (red white and yellow) that I think I used the last time I attemped this. But there is no red plug in the back of the vcr(or the red one isn't used)
    Can someone walk me through this?
    Dec 2003
    Stevenage, nr London, England
    9
    if both of the vcr's have areil in and outputs take the wire from the out one one and put it into the in on the other if you want to watch at the same time conect this out to your tv hope this helps
    1 Wife
    3 Kids
    Honda big red
    Honda 400/4
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    The three pronged cable you have is an Audio/Video RCA cable. The yellow is for video, while the white and red are for left and right audio. You can still use this cable as long as the yellow and either the red OR white end is connected to both devices. The audio will be in mono vs. stereo in this configuration, but with todays A/V technology, it's not that big of a deal. Just connect one end of the cable to whichever device has output jacks and the other end to the inputs of the other device. Use the output device as your player and the input device as your recorder. Should work just fine.
    Hope this helps...
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
    Pa.'s Highest City
    8,058
    Red face This may help...
    this is the back of the vcr
    back of the tv/vcr
    front of the tv/vcr
    wires
    I also have a regular black cable with the screw in ends. but I'm not sure ifi need this.
    Jan 2005
    RI
    2,530
    from the back of the vcr do audio/video out ..white goes in the audio yellow hole and yellow goes in the video yellow hole and then put the audio white into the white hole on the tv and yellow into the yellow hole and you should be set.
    read your pm
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    RI
    2,530
    have the TV record onto the actual non hooked up to tv vcr and you should be all set.
    put the black coax cable from the ant out to the tv's cable port. put the coax cable from the wall into the ant in on the vcr.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Dec 2002
    Kansas
    2,387
    This thread makes me laugh.
    Back during my single days in the mid 90's my roomate and I hooked up my stereo, tv, vcr and his vcr. It always worked perfect except for the 2 times we rented dumb and dumber and neither time did we get it recorded.
    I know we had one heck of atime getting it all rigged up. The remote control confusion was unreal.
    I had the RIGHT to remain silent, I didn't have the ability!
    Jun 2004
    Ohio
    1,026
    What DeePa said, but you don't need the coax AND the RCA's. They both do the same thing, just in different ways. One or the other is enough to get the job done.
    1986 TRX250R
    Jan 2005
    RI
    2,530
    if hes recording something over cable on the tv he has to.
    the vcr on the tv doent have any video out.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jul 2004
    Mud hill. close to water !
    3,658
    I remember recording my dad's porn as a kid.. was easier than having to set the counter and re-wind it back to original position hehe...
    If you use the TV remove and move the chanels down below chanel 2 .. it might go to " aux " as in auxiliary, so that it receives the singal from the other vcr. that or the remote should have an " Input " or other feature.
    Currently :
    Pa.'s Highest City
    8,058
    Quote Originally Posted by smokinwrench
    Haaha.. I make those guys look like rocket scientists.
    Well I tried what you guys said and it did not record. I had enough of this for one night I will try again tomorrow.
    Tionesta, PA
    5,747
    chris200X
    set your TV/VCR combo to one of the following (depending on options of TV or make and model)
    A/V1
    Line 1
    Input 1
    A/V2
    Line 2
    Input 2
    Put a tape in the external VCR and push play - go through the above until you see it playing on the TV. Then you'll know it's hooked up right. Then just play the tape in the external VCR and push record on the TV/VCR - you have to be on Input (X) for this to work, not a channel. When using RCA jacks (red/white/yellow) it is not channalized like regular coax (3,4,5,6 ets)- it is a composite input signal. Questions??? Pm me.
    Nov 2004
    Fort Kent, Maine
    2,132
    I think someone needs a DVR...... lol
    You need to hook your cable (coax) in put to the vcr first.... then hook those rca cables from the vcr out to one of the tv's inputs, then go to the corresponding auxiliary channel and you should be set.
    But like I said.... get a TiVo lol
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Pa.'s Highest City
    8,058
    I got it guys thanks.
    I got it to finally play on the vcr and used the tv/vcr to record it.
    What the heck is DVR and tivo?
    Jun 2006
    Ohio
    2,294
    Quote Originally Posted by chris200x
    Digital Video Recorder. Ya, those are nice but you can't record Black Water vids!
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
