Results 1 to 15 of 15
Thread: o ring and none oring chains
    leroy, new york
    1,025
    which do you prefer and why, or does it depend on what kind of bike.
    Pennsylvannia
    1,147
    I prefer O-ring or X-ring because they generally last longer.
    leroy, new york
    1,025
    i never heard of x ring whats the difference, comparing the two.
    Pennsylvannia
    1,147
    An O-ring is like a round piece of rubber shaped into a circle, and an X-ring is an X shaped piece of rubber shaped into a circle. X rings supposidly seal better I think?
    85ytz250n is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Waynesboro, MS
    338
    I prefer the free chain that I get from work, I dont care if it lasts a week or a year, its free to replace. If I was buying I would definetly go with the O-ring though. The rings keep dirt and grit from getting inside the link where it pivots, making it last longer and stay lubed longer. You do have to maintain the O-ring chain with the right lube, but you should do that with any chain.
    Barry
    There are no stupid questions, but there are alot of stupid people out there that ask questions.
    None of us are capable of screwing things up as bad as a group of us.
    "NON SIBI, SED OMNIBUS"
    Fresno Ca
    2,695
    I wont waste my time with non oring anymore. I will go through one in a weekend (even with new sprokets)
    Phoenix, AZ.
    6,719
    I don't even use chain lube on my x-ring D.I.D. chain. Just WD40.
    Ontario, CANADA
    4,538
    Yah I got a gold X ring DID, I just use normal lubricant on it. Had a O ring before, nothing major in difference.
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    if its cleaned and oiled after each ride they will last a long time
    Tionesta, PA
    5,747
    x-ring is the same as o-ring except you get a "double seal" effect from the "X" shape cross section. For my little riders that don't get too much use (70's - 90 - 110's) a $25 non o-ring chain is fine. They have enclosed chain guards and I keep them out of the mud. For something with power, like my 350X o-ring is a must. Can't really keep mud off of it's chain. I recently put a non o-ring chain on my 350X and it needs replaced already - maybe 20 hours on it - and it is completely shot!!!. They seem to streach more or something - Sure you'll pay 3 or 4X more for an o or x-ring chain, but you'll replace it 3 or 4X less. The rubber ring keeps tiny mud / dirt particles out the chains joints, and gerneally that is what ruins chains!
    Oregon
    2,471
    What brand is top notch for the X ring and O ring ?
    do they have it in gold ?
    Ontario, CANADA
    4,538
    I got a DID X ring in gold, from rockymountainatv.com
    #NOLINK
    #SUSPENDTHIS
    Jan 2005
    Orange County, CA
    119
    I bought the cheapest oring chain from rockymountain and have been running it on my CR500 with no issues. It also has openings in the sides of the links to let crud pass through. Might be the ticket for you mud riders.
    1985 ATC 250R
    1986 ATC 200X
    1986 TRX 250R
    Jun 2006
    Illinois
    491
    X-ring chains spin a little easier than standard o-ring chains and are usually slightly more expensive. I just like the fact that I don't have to adjust it after every ride. D.I.D. makes a good x-ring. They probably last about the same as a standard o-ring chain, but it's less HP loss because of less friction. It just depends on what you want to spend.
    Pennsylvannia
    1,147
    Quote Originally Posted by ceaserthethird
    I would have to say RK is one of the best. They are quite expensive though.
