Results 1 to 3 of 3
Thread: No Lights 85 250R
    Antioch,California
    149
    No Lights 85 250R
    Which lead comeing out of the engine is for the Head/Tail Lights?
    Is it Black/Red or White/Yellow ???
    I was thinking I could run 12 volts DC to the right lead to find the short?
    Antioch,California
    149
    Also on the Rectifer it has a green wire and a white wire. Which one is AC in and DC out ? Maybe I can hook 12 volts DC to one of these wires, to test for shorts ???
    Also what is the OHM readings for the Ign Coil and Lighting coil? Rectifer have a Ohm reading?
    na
    5,702
    i think on the hondas,the green wire for the regulator is ground.the white is your power in. as far as the stator wires,i am not sure.check the wire diagram page on the 3ww home page.it should tell you.if you keep blowing bulbs your regulator is shot
    Proudly NOT a member of
    "Team on the Teat"
