Results 1 to 7 of 7
Thread: Dual front brakes... any need?
    Mar 2004
    North Central Ohio!!
    2,712
    I've been kicking around the idea of adding some inverted front forks to my 250R this winter, and while I was at it, I thought a new billet hub would be a good addition. One that would accept a more common Quad front rim.
    Then I was thinking, It would be just as easy to add a second front brake if I make a new hub. Kind of like the bigger street bikes.
    Think this is over-kill? Ever seen a trike do a stoppie?
    PA
    3,515
    i say theres no need...with 1 disc the front normaly just skids
    WWW.HREATV.COM
    May 2005
    Dorset United Kingdom
    1,408
    Probably no need, but it would look real cool
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Mike_Ham_250R's Avatar
    Mike_Ham_250R is offline Even team-red-rider is cooler then me. Arm chair racerJust too addicted
    Pennsylvania
    1,058
    Derrick you don't need two brakes on the front. I recently got EBC pads for the front on my 250r and I bled them to the point where the brake lever is extremely tight. And yes I took it out on the pavement and I was able to do a stoppies and ride it out for a couple of seconds too. When I get to it I will post pics.
    -Mike
    Ontario, CANADA
    4,538
    I definetly like to see that.
    I say go for it derrick, your R is custom as is, why not add some more?
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    seems like extra weight to me. maybe a larger rotor and somekind of exotic caliper would be cool
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I'm running the cannondale quad master cylinder and KTM520 front caliper on my Z and it REALLY clamps. I wouldn't grab more then 1/4 of it at one time on the pavement if someone paid me to do it!
