Results 1 to 8 of 8
Thread: top end replacement
    Dec 2005
    Blackwell, Oklahoma
    22
    top end replacement
    i am wondering if it is very hard to replace a top end i have all the parts and a manual i am i just wondering how hard it is?
    holmstrom is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    bryan ohio
    221
    I guess it depends on what kind of trike it is. On my 2 stroke ty125 its real easy. On a 4 stroke it would be harder i believe.
    2 125 yamaha tri motos
    1 yt175
    1991 blaster
    hoser's Avatar
    hoser is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2005
    ILLINOIS
    284
    It depends on your skills, read the manual a few times if you find yourself asking too many questions or don't fully understand everything you read you might want to have someone with experience with you your first time.
    What engine are we talking here?
    Dont make all the rookie mistakes, don't use cave man tools and techniques like prying things apart with a screwdriver, trying to pull the flywheel off with a 3 jaw puller, don't use a unless you see a picture of the mechanic in your service manual beating on the same part you want to beat, don't use power tools to clean parts or to remove old gaskets, don't be in a hurry only attempt this if your ready to spend a few weeks on the project, once apart you might find something wrong and need to order parts, buy the special tools required if shown in your work steps of the service manual, some tools can be made some are not worth making and are worth buying.
    If you don't know ASK BEFORE attempting!
    The only dumb question is the one NOT asked if you feel embarrassed to ask what you think is a dumb question in public send me a email and ask dumb questions dont bother me I ask plenty myself...
    Dec 2005
    Blackwell, Oklahoma
    22
    well the motor is a 85 200x and i just put a new clutch so i kinda know my way around the motor but mainly just the bottom end
    hoser's Avatar
    Nov 2005
    ILLINOIS
    284
    Quote Originally Posted by brown07
    Thats good you have a feel for the bike already, again go through the manual step by step see what you think, I have never done a 200X so others here might be able to lend you better info, study that manual...
    ATCR250R's Avatar
    ATCR250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Norfolk, NY
    319
    If you are just looking to bore it and put in new piston and rings then you should be able to do it easily. The timing is the hardest part and if you know how to do it the rest is cake. I timed my 200X easily but now I cant remember how for sure. I believe all you have to do if I remember right is bring it to top dead center, put the cam in with the lobes facing down I think it was, then bolt it up lineing up the marks on the gear with the head marks. You are going to want to be sure though seeing as you wont want to bend a valve.
    ATCless at the moment...
    1977 Firebird Formula
    1997 Suzuki RM250
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    I did our 200x very recently and it wasn't very difficult, just took a few weeks between waiting for parts to come in and also waiting on the local shop to do some cylinder work for me. The timing is pretty simple if you have a factory honda service manual, I had that and also a Clymer manual which didn't seem to be as detailed but still helped. If you need any help with the timing send me an email and I can explain it step by step or anything else you need for that matter. Lastly, good luck.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Dec 2005
    Blackwell, Oklahoma
    22
    well i will continue to read thru my manual and i will prolly start on it this weekend thanks for all the help
