What year banshee bearing carrier bolts to the tri-z? 87-88 or 89 to present?
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
none there wider... as far as i know....
Then how did 2extreme put one on his z??? Im not looking to put a carrier on im looking to see if the swinger extensions have the same bolt pattern.Originally Posted by bryan raffa
2006 YFZ 450
i have a z swingarm and a ton of banshee carriers. if ya give me a few days,i will research this as i want to do the same for my new z project. i am sure it will work.i think you have to use a 87-89 basnhee carrier. 2xtreme went thru a lot of fab work making a new aftermarket carrier work.i think the early banshee carriers are almost a bolt on deal.but i will have to check.
Proudly NOT a member of
"Team on the Teat"
Thanks, i just need to know if the bolt patterens are the same. The carrier dont have to fit.Originally Posted by moshman355
2006 YFZ 450
i tried the old 87 two bolt carrier setup
it is wider but fits after you spread the mounting tabs...
and you have re drill the bottom hole , its off just a hair
sounds good to me.Originally Posted by 03 ORANGE SHEE
2006 YFZ 450
