Results 1 to 10 of 10
Thread: 350x 55w bulbs???
    Nyssa, Oregon
    13
    350x 55w bulbs???
    Will my 350x handle 2.. 55 watt H3 style halogen bulbs??? I am running a 35w H3 and a 55w H3 now, but not at the same time...
    When I got the trike all the bulbs were blown.. I bought a used voltage regulator and decided to use H3's because of the price... I machined a spacer and hold the bulb in with a pin, seems to work fine...
    thanks, Vern
    Nov 2001
    B.C.
    933
    I seem to recall that the stock 350X stator will support 100 watts. Any confirmation?
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Nyssa, Oregon
    13
    I guess if the 100w support is true, That answers my question... Thanks
    bobr is offline First Time Rider Arm chair racerNew to the board
    Dutchess County NY
    101
    wattage
    Try 200 watts ,I think that's what the shop manual says. Bob
    Parting out 1984 200X and 1985 200X
    Nyssa, Oregon
    13
    Uh-oh,, Back to where I started.. That would be great if it were 200 watts, I could run both 55w bulbs....
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    i think the banshee bulb fits the X. i know i had two yamaha bulbs in mine.
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
    >->->->Hgoody77@yahoo.com
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    You can get the stock 35 watt bulbs at Napa. They are less than $8 each
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Nyssa, Oregon
    13
    Quote Originally Posted by ATCnut
    The stock bulb is a 35/36.5.. You can get that at NAPA for less than $8 ?
    Still wondering if the stator and or wiring will handle 2-55w bulbs..
    Does the stator put out 100w or 200w??
    Nov 2002
    Auburn Washington
    799
    The honda service manual states that the alternator puts out 200w @ 5000 RPM. Some, it is hard to know how much goes, to the regulator. Being it is a shunt regulator it might be more than half. What you may find with higher wattage bulbs is that they are dim at lower RPMs.
    The NAPA part number for the stock bulb is HM202. The only thing you have to watch out for is that some of them are kinda tall. I had to file down the connection bumps on the back to fit it into my light.
    The other think to be careful of is that higher wattage bulbs generate more heat. They might overheat and burn out that way.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    85 350X (the best)
    Nyssa, Oregon
    13
    Thanks. ATCnut... That is some good info. I think running 2-55w bulbs might be a little hard on everything. Thanks for the NAPA pt. #
    Vern
