its stripped...cant shift
where can i get a new one or should i weld it on?
Chirochris,
do yourself a favor - PLEASE DON'T WELD IT!!!!!!
You can get cheapo aftermarket shifters at you local bike shop - Emgo makes one that will fit. Or you could order and OEM, but they can be pricey - upwards of $50. Or you could put an ad in the classifieds here on the boards and someone will sell you one - or check Ebay - but please please do not weld it.
Do Not Weld It! Way too many people do it and it just causes more problems.
Are you talking about the shifter or the shaft? What trike?
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
Are the splines totally stripped ? or still have a little bit of bite ?
Sometimes you can get by with widening the gap where the bolt goes thru to allow a bit more torque by the bolt.. but a new shifter is cheap and well worth it.. avoid the welding option if at all possible.
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
that happened on my cousins 225dx. we justv jb welded the S.O.B. on there.
still on ther to this day
just drill a hole through the shifter and the shaft then put a bolt through. that way its still removeable and it cant slip
"And I bled out of here, and here, and here and here.........."
'84 200M-Cobra pipe-sold
'99 honda 300 fourtrax-2 inch lift, Bearclaws on ITPs
1981 honda 185s-Ole Smokey! :
1987 Honda 250x....well in theory
