Hi I have a yamaha 225 dr 1986. Newer rings piston bored timing chain. The problem is sometimes it will not run over 3/4 throttle. Then for no reason it will start running like a raped ape for a couple weeks then back to 3/4 throttle again. Dam thing anyhow. Been through the carb a dozen times Its spotless. Cleaned coil connections and checked for loose or corroded wires. I took the spark plug boot apart today . Never seen anything like that before. Anyhow any help on this would be greatly appreciated. THANKS!!
to the boards.
