Results 1 to 10 of 10
Thread: Thought I had a new parts BIKE!!!
    Okay we were up riding today out about 10 miles from the rig. coming down a steep hill. and all of a sudden my wifes 200x locks up. I check it out, put it neutral and try to restart it but its seized up. I figured it was toast. So I went down and got the rig and trailered it up and drove home. Well when I unloaded it I Tried the kickstarter again for sh-ts and giggles and it fires right up. What the heck happened there! Is the motor running lean and making it hot? Has anyone ever had this happen before? I rebuilt the carb a while back but the motor is still in the same shape as the time before we took it out. any input would help. I feel like I dodged a bullet on this ride.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Ashland City, TN
    2,576
    Welp I don't know the answer so here's a theory, is it possible that the piston got too hot, making it too big around for the cylinder and it made it stop?
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    hows the oil look? does it smell like toast?
    Work smarter, not harder
    Rides:
    '85 350x
    '80 cb650c
    sandrooster is offline At The Back Of The Pack Arm chair racerFirst time rider
    mom's house
    193
    Spark plug!
    Check the color. It should be medium light brown.
    If its light light brown to light tan, your carb is too lean.
    85 ATC250R
    Thanks I forgot to do that. I'll check it. Do you guys think the motors okay with a little life shaved off? It sounded all right. no noise, or smoke.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    I checked the plug, looks to be running on the rich side if anything.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    maybe your fuel got to hot and caused vapor lock or something heck i dont know. your lucky though ill say that bro
    finding a good bike is like finding a good woman, it might or might not happen so hang in there.
    Tri-Z dude is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    are u sure trailprotrailpro oiling hole to the cam isnt clogged up
    my 225DX oiling hole clogged up and melting the bushing around the came and siezed it up
    i hope thats not what happened in trailprotrailpro case man
    good luck
    my locked up goin down the road and i pushed it about a mile(6miles from home) and i tried starting it back up and it started first pull
    drove it cause i thought it was a fluke thing so after a day or 2 it siezed up for good
    got the motor all back together and i just need to torque the nuts and bolts and stick it back in the frame
    hook up the rear end
    put oil in the engine
    gas in the gastank and put everything back on it and start her up
    i put a .050 wiseco piston with another stock cam and rockers in a diff head(thats 84atc250R) and new gasgets and orings etc.
    clutch and drum also
    all together i got 180 in all for the DX this time
    114 for hole top end and 43 for the stuff i got from Jared
    and i got some odds and ends from the yamaha shop also
    i paid 75 bucks for the piston and rings brand new
    30 for the gasgets etc.
    then include tax its 114
    i hope u dont have to go through the trouble that i had to
    good luck and hope thats not the problem
    Ben
    1982 Honda 200
    1984 yamaha 225DX
    1984 yamaha 225DX parts bike
    1986 Honda cr250r (soon to be trike)
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    I had a problem like that with my 83 200x. I had broken a tooth off of one of the kicker gears. The broken piece got jammed up, then jiggled itself loose. If there is a loose piece in her motor somewhere, it could have vibrated out when the trike was bouncing on the trailer.
    The other potenital is that the shifter is slightly bent, such that when she shifted, the tranny jammed. Again that could have cleared with the jiggling on the trailer.
    I would keep an eye on it, and keep riding
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Thanks, that one makes sense to me, I'm going to pull the sidecase and change the oil and clean out the oil pump. and maybe sweep a small magnet around in there.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
