Thread: 110 jetting
    Indiana
    115
    Question 110 jetting
    Ebayed a new Jardine canister muffler. The info says I need to rejet. How do I determine what jet I need?
    Feb 2006
    Central Florida
    1,090
    guess.
    thats about all you can do that i know of. do you have an open air set up like pods or anything other than stock?
    After you install your pipe and take it for a test run you should be able to determine how much more fuel it needs at top end.. the main jets are for 75% to 100% throttle so give it all she's got and see if it bogs down. if its a little boggy go up one jet size...if it is super boggy at top end try a couple sizes bigger (hit your choke to make sure its too lean - if it runs better with the choke on that means its too lean)
    to make a long answer short - i really DFK, but this works out pretty good and youll wind up with a few extra jets to play with next time your tuning something.
    BTW - I am assuming the pipe will require a richer jetting because of a loss of backpressure increasing the intake like i said I D.F.K. but i hope this helps a bit.
    quiet people seem intelligent
    Indiana
    115
    I guess I should have noticed the sticky on jetting.
    Feb 2006
    Central Florida
    1,090
    sticky? the post?
    Oh - i see it now - yea good info!!
