Results 1 to 15 of 49
Thread: creek riding went bad
    Jul 2006
    western ny
    3,366
    well i went creek riding with my 200s. but wen we got back it sputered and wanted to die. it only happens when i go up hills. it is fine as long as it is on flat land. it will go up hills in first and second gear but wen i try 3rd gear it sputters. what can it be??? could i have sucked in water?? or could i have blown out my rings??? im lost i spent all day trying to figure it out.
    please help a fellow 3 wheeler rider out.
    didnt get many pictures but heres 2 of em. im kinda p!$$ed that they didnt get more and better pictures. sorry for lack of pictures guys
    GIT IT RAAAGGGGG !!!!
    Pa.'s Highest City
    8,058
    Lol... Time to clean the airbox/filter and the carb. This is the exact thing what happened to me after I sunk my SX in a mudhole (My avatar.. ) It would sputter in the higher gears when I gassed it. Might be a good time to change the fluids as well. Don't wanna be running motor oil if water got in there.
    Jul 2006
    western ny
    3,366
    i hear you. ive dumper mine in a "pond" more like a huge mud puddle. i dont run a air box i run a snorkel. but it was pooring out side so it could have gone it due to i dont have a filter on it yet. i run a snorkel mostly cuz wen i got my trike the guys nefu lost alot of parts sadly the air box was 1 of em. soo i had to impervise.
    that black thing is my snorkel so far lol u do funny things wen u run out of $$$$
    Pa.'s Highest City
    8,058
    um,,,
    Oh my!
    Jul 2006
    western ny
    3,366
    hey now its better than a bare carb under water aint it????? well it works ok. juss not wen its raining lol
    Aug 2005
    HI
    1,575
    Might be a good idea to run that snorkel a tad higher and add an airfilter to it.
    Rest in peace Rex Carlson
    Jul 2006
    western ny
    3,366
    yea i no im going to try to get 6 inches on it + a filter
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    you might also want to run a pipe coming out of your exhaust so you dont get water running down your exhaust pipe and back into your engine.
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    Jul 2006
    western ny
    3,366
    yea thought about that and i will probl be doing that tommarow. i hope lol
    illinois
    743
    1 well it looks like it smokes so it might be time for new rings for one
    2 it is going to resrict air because the hose diamiter? -even when you add a filter
    it will be worse might need to jett down (leaner) check the plug and see what it looks like you want a tan color --- not -black-thats rich-- not wet
    and not white --thats too lean
    yea im sure it probably has water in it lol
    is the electrical sealed???????? it gets wet too
    Dec 2003
    australia
    838
    Well the mere fact it runs is a true testament to how well Honda builds things.
    It has most likely sucked some water into the carby. Drain the fuel out the bottom of the carby into a container and check to see if it is contaminated with water. that goes for your fuel tank also.
    The carby should have a hex head plug at its base or a drain scew outlet. Failing that, take off the float bowl. Be careful when you do that though, If money is an issue, you don't want to wreck the gasket or break any parts.
    In regard to your air inlet setup. The hose diameter for that type of engine doesn't look too small, just filter the air going in somehow. If your always going to go swimming with it, mount the hose higher. Lots of Trikes had the air inlet feed from up near the head stem, see if you can rig up something like that. Also put on a pod filter by crikey man.
    You may also be having some electrical issues. Squirt water dispersiant (WD40,CRC,INNOX etc..) into the magneto/points pick up area and onto any of the electrical connectors
    Oh, and get the seat recovered you slack arse and have a bloody haircut!
    P.S. good luck with it.
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
    Aug 2004
    Nampa, Idaho
    1,245
    When I got my 200x the seat looked like yours. I bought a piece of vinyl from a junk store for a dollar and put it over the original seat. Its not perfect, but its not poking me in the butt either.
    Jul 2006
    western ny
    3,366
    my plug is tan and my rings better not be bad ther 1 year old and i havnt drove that three wheeler much. lol yea i no i need a new seat coved and i will do it when i get some time and money. but first i need to fix it there is no since in redoing the seat if it dont run.
    ps i dont want a hair cut.
    Feb 2006
    north of buffalo
    557
    where abouts in ny are you 84honda200s? Is that foam zip tied on your forks in place of boots?, i like.
    Runners:
    84 200s
    05 rancher
    12 rancher
    Jul 2006
    western ny
    3,366
    i am from springville "about 20 miles south of buffalo" and no its not foam lol it is my tow strap that i use wen i get really stuck in mud. oooo yea guys i fixed my seat well for now anyways.
