Results 1 to 15 of 16
Thread: 85/86 250r question
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    85/86 250r question
    can 86 atc 250r pegs be bolted onto an 85 atc 250r? thanks- matt
    3leggeddog's Avatar
    Nov 2004
    is this a trick question?yes they can.
    wanta86r's Avatar
    Nov 2004
    mn
    385
    i thought so, but i know there is something different about the 85's. i've just never had a 85, but 3 86's.
    Oregon
    2,471
    their is a difference .... but what is it ?
    wanta86r's Avatar
    Nov 2004
    mn
    385
    i think the 85 pegs are narrower. the holes in the frame for the mounting plates are the same though. you just cant mix and match 85 and 86 pegs and mounting plates.
    Jul 2006
    Minnesota
    6
    I have both an 85 and 86 250r atc's and just went and took a peek at them and the pegs and brackets look the same.
    Jun 2004
    potsdam ny
    1,227
    yeah they will, but you cant use aftermarket pegs on the 85' peg backets.
    wanta86r's Avatar
    Nov 2004
    mn
    385
    Quote Originally Posted by hrc85250r
    so if the peg brackets are different than the peg itself is different also - correct?
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    So, are you saying with the 86 model you can use an aftermart peg, then use the same mounting bracket?
    so, are the 85 pegs actually narrower? look at were the spring mounting part is on yours Zipper. see if they look different there?
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
    >->->->Hgoody77@yahoo.com
    wanta86r's Avatar
    Nov 2004
    mn
    385
    i do know for a fact that with 86 mounting plates aftermarket pegs(Ims Roll Design) will mount right up
    Jul 2006
    Tampa Bay, FL
    17
    Would those be IMS pegs made for the TRX250R? Their website doesn't list any pegs for an ATC.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Yes as long as you get the 86-87 TRX style instead of the 88-89 style The earlier ones mount with a pin and use the original mounting plate. the later ones come with the mounting plate integrated and the bolt pattern/spacing is different.
    Jul 2006
    Tampa Bay, FL
    17
    Thanks for the info. I was looking to buy these in the photo. They are supposedly for an 88/89 but have no integrated mounting plate. Any ideas?
    Live Oak, FL
    15,069
    Hmmm...nope. They look like they mount different then the ones I bought though.
    wanta86r's Avatar
    Nov 2004
    mn
    385
    Quote Originally Posted by mrbones
    those look like the 86/87 trx pegs that i have to me
