Results 1 to 11 of 11
Thread: I'm new here
    Mar 2003
    7
    I'm new here
    Hi all. I got 2 3 wheelers. 1st one is a 1983 atc 110. Runs for the most part, but like any old thing it needs work. The other one is a ATC 125. Not running. My question is are the parts on both bikes the same? Can i swap trans on the bikes?
    Please help me
    Thank's
    als250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Hey Gus, Don't know about parts interchange, just wanted to say "WELCOME!!" :-D :-D Somebody here will be able to answer your question.
    Al
    TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
    '86 350x (latest addition)
    '85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
    '85 250sx(supertrap exhaust,chrome rims)
    '87 200x(restored)-'85 200x-'84 200x
    Chemical442's Avatar
    Chemical442 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Central IL
    204
    What's up, Gus? Welcome
    • Rebuilt '79 110
    • Rebuilding '82 200
    Howdy's Avatar
    Celina, Ohio
    10,079
    1st off: Welcome to the site. I hope you enjoy it.
    While they look the same the 125m and the 110 trannys are different. Sorry!! If you need tranny parts I may be able to help. ( I am sure others here can help as well ).
    Thanks
    Howdy
    Mar 2003
    7
    ok well here I go. In low range i have 4 gears. In hight range I have no gears. What could it be?
    The only othe question is will the muffler from the 125 bolt on to the 110?
    Dec 2002
    749
    WELCOME!
    Apr 2002
    s.w. michigan
    6,498
    hi gus
    hey welcome aboard there gus !
    i would start simple and that would be down at the lever you flip back and forth for your hi/lo ranges. i am pretty sure you can take that cover off with out draning the oil.
    just look it over and get a feel for what it's supposed to do + ya might see why it isn't engaging your high range.
    good luck ! john
    Roanoke, VA
    4,038
    WELCOME to the site!! Hope you enjoy
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Welcome nice seeing new names!
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by gusgreenwall
    If you have low range but no Hi range the sub tranny is where to look. You can remove the cover where the hi/lo lever is by removing the 4 screws. Once inside you might find good news or bad news. The good news would be just a part out of wack. The bad news is a broken gear. If it's the 125m with the problem it is worse because those gears are hard to find in good condition. If it's the 110 and it's a gear broken I should have one.
    I recomend a clymers or OEM manual for working on it. A $30 manual will save you Hundreds of dollars over taking it to a dealer.
    We can try to help also.
    Howdy
    Mar 2003
    36
    hey welcome i dont have anyparts so im sorry i cant help you ok will good luck l8ter.
