ive got a 1984 honda 200s. the rear brake needs work but i cant seem to get the drum off. i have the hub, brake cover, and 2 large nuts off. the drum is not loose and im not positive on how to remove it. is it just rusted and seized on good, or is there something else i need to remove? it did look like there is a small round ring on the outside part of the drum.(its close to the same diameter as the 2 large nuts and it would be right next to the inner nut) does this ring need to come off before the drum can? the ring doesnt appear to make contact with the axle, just the drum. also, is the drum locked in place with splines, much like the hubs?
if it is just seized on good, does anybody know a good way to break it loose? im thinking i can modify a bearing puller to do it of there is no easier way. i need help asap so i can go trail riding with some friends.
it out.
