Results 1 to 3 of 3
Thread: Carb question
    az
    2,040
    Carb question
    Sorry this is on a Z 50 honda, but I think the carbs gotta be the same as say a 70. I pulled it apart, this thing was bought as a basket case, carb was filthy. I don't have a kit for it but when I pulled it apart I noticed the fuel inlet was 90% plugged. I ran a small drill bit back and forth through it by hand and flushed it with carb cleaner. finally cleared that up.
    main thing I noticed it there is two brass tubes hanging down from the top part of the carb into the bowl.
    the large one you can stick a needle throught it, and blow air through it. the smaller of the two is completly blocked. Is it suppose to be blocked? or is it just clogged up? Ive run a pin vise through the larger one on a atc before, before I do this I just want to make sure Im not going to mess something up. thanks Jim
    Antioch,California
    149
    Small one is your Idle Jet. Run a small Wire through it. A Wire from a wire brush works great for this.
    az
    2,040
    so its not suppose to be clogged then. thanks Jim
