The pinion bearing failed and caused my differential gears to get chewed up pretty badly; I need to replace them. I'd like to find a complete differential and just swap over the complete unit; I'm sure this would be far cheaper than buying new gears and having the local Honda shop rebuild the unit. I just need to find one now.
Are there any other machines that shared the same differential unit as a 1985 250SX? 250ES or a Fourtrax 250? I see that even the new Honda Ranchers have a very similiar looking differential, would it fit? I'll be going to the salvage place on Monday.
I do have a '86 Fourtrax 250 (at my mother house 200 miles away...) with a complete rear swingarm and suspension; if I can't change out just the differential, would the complete swingarm fit my SX? I'm already going to run the 9 inch rims off of it, everything else is setup the same. The engine is even exactly the same as my 250sx. If the frame is the same width at the swingarm mounts and the driveshaft connects I don't see why it wouldn't work. Anybody got a Fourtrax nearby they can measure for me?
