Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 75
Thread: Help needed. 250sx swingarm bearings
  1. #31
    Pa.'s Highest City
    8,058
    Well I just went ahead and ordered the holders and seals. Should be here today.
    This thing in the pic I posted has me concerned for sure. I got it soaking with pb blaster right now. but what do you guys use to get it out. A blunt chisel and ? I think that is going to mess it up for sure. Anyone know what the correct tool or part number the tool is to properly remove this thing?
    EDIT: DOH! A 17mm nut fits right in there.. I'll have one welded to a bolt and use that.
  2. #32
    springville, PA
    6,185
    chris it is called a big ass allen head wrench, we have one . If you want to borrow it lemme know and I can send it down to ya.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
  3. #33
    Mar 2005
    ma
    988
    Quote Originally Posted by chris200x
    you could also use a 17mm bolt, a long one, and bend it 90 degress to act as an allen wrench
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
  4. #34
    Pa.'s Highest City
    8,058
    Quote Originally Posted by sblt500r
    I guess these will work just as good
    So I'm having a heck of a time getting these hubs off. Do they just slide off the end of the axle?
    Lol.. I got moldy rear brakes!
  5. #35
    springville, PA
    6,185
    Chris put the drum back on. If you notice there are two holes in the hub and two on the drum. There are supposed to be screws holding them together. Thats probably the easiest way to get the hub off is to pull everything at once.
    Nate
    R.I.P HRR
  6. #36
    Pa.'s Highest City
    8,058
    Well, I got me some new brake shoes to put on the back here. Now is as good as time as any I suppose.. So the backing plate and hub are supposed to slide off the end of the axle? it seems to be a bit frozen.
  7. #37
    Pa.'s Highest City
    8,058
    wtf?!?!?
    I've been pounding out this hub for the past 45 minutes and it ain't budgin... Are they threaded on?
  8. #38
    springville, PA
    6,185
    no just slid on. its just like on the quadrunner if you want to look at that. PB blast it, let it sit over night and try again tomorrow
    Nate
    R.I.P HRR
  9. #39
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    Have you got access to a oxy acetylene torch? A bit of heat would probably make it come off.
  10. #40
    Mar 2005
    ma
    988
    yeah, you have to heat them, chris. they've probably been there since it was new
    My Feedback
  11. #41
    Pa.'s Highest City
    8,058
    Angry
    Yes... Not to many bolts have been turned on this machine.. I heated the hub to a point where I started to melt the axle bearing seals... Still ain't budgin.. Most of the other bolts (besides the lugs) had to be heated as well to remove..
    21 years of coal dust and water sure do a number on these things that's for sure.
    Well boys I am outta ideas for now.
    Is there a better penetrating oil out there than pb blaster?
  12. #42
    Pa.'s Highest City
    8,058
    Red face
    If it's not to much trouble John. If I can get the hubs off I think the rest of it should go rather smoothly... (hoping)
    Oh, thanks for the copies!
  13. #43
    Pa.'s Highest City
    8,058
    Talking john....
    I got it!!!! (the axle out that is)
    But the hubs are still stuck on the ends of the axle carrier.
  14. #44
    Pa.'s Highest City
    8,058
    tonight's progress...
    This is what I can accomplish with a 12 pack!
    I cannot slide the axle through the gearbox.... Any suggestions..?
    Also that freakin hub aint budgin........
    I had to grind through the races to pry them out... no easy task..........
  15. #45
    Pa.'s Highest City
    8,058
    Damn John,, that thing is hardcore!!!
    The problem I'm having with the axle.. There are stops or "bumps" on the end of each side that the bearings rest up agianst. I cannot get it through the gearbox. That, and the one hub ain't budgin. I actually bent the hub a bit with that 2 pronged puller. I think your creation may work a bit better.
    Does the gearbox have to be split or something?
    Pm me when you get that badboy finished up and let me know what I owe ya!
