Results 1 to 7 of 7
Thread: Wont start.
    angryyoung is offline At The Back Of The Pack Arm chair racerFirst time rider
    Ontario, Canada
    164
    Wont start.
    I just installed a new throttle/oil pump cable and choke cable on my Yt175 and i cannot get it to start. It fires when i put some gas in the cylinder. It was sitting for about 4 months i think. Would the gas have clogged up the float by then? Should i clean the carb?
    I had it running a few months ago for about 5 minutes.
    Oct 2005
    Pennsylvania
    863
    Try it with the gas cap off----
    If not there is a screen on the petcock and Clean the carb.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Ontario, Canada
    164
    thanks! the petcock is the part where the off/res/on switch is for fuel right?
    Jul 2006
    western ny
    3,366
    yeppers be careful when you take it off so you dont snap it. if thats not pluged up then put fresh gas in and clean the carb out.
    GIT IT RAAAGGGGG !!!!
    Ontario, Canada
    164
    thanks, also, what do you think would be a good oil to run in this machine for summer? what viscosity?
    Apr 2006
    Crestview, Florida
    2,429
    10w40 or 20w50
    illinois
    743
    pick up some klotz ,you can use the mx4 for the crank case ,and the 2 cycle for premix -or oil injeted
