Thread: 350x axle removal question
    Nov 2002
    66
    Hi Guys,
    I am having some trouble removing the rear axle on my 86 350x. I have losened the inner locking nut, but can't seam to loosen the outer one. Am I correct that they are both left hand theaded? Any advice would be appreciated.
    Thanks,
    Chris
    there both thred the same way try some heat and lube.
    wolfspider's Avatar
    wolfspider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    HARROGATE, ENGLAND
    376
    350 axle
    hi the axle nuts have a left hand thread which means they move towards the disk when you loosen them, this then moves the nut away from a collar that has a snap ring underneath, remove the snap ring and the axle nut and thread will pull off the axle. hope this helps.
    steve
    HONDA ATC250ESJ 1988
    HONDA 250R `85 restored SOLD
    HONDA ATC 350X `86 restored SOLD
    HONDA ATC 250ES `87 SOLD
    YAMAHA YZ100 `80 project
    HONDA ATC350X `85 PROJECT FINISHED
    Jul 2003
    Cheyenne, WY
    56
    I was just working on mine and that axle nut was definently a pain in the butt. The reason why it was so hard for me was because it was so big counldn't find a good wrench to get on there. Now the problem I'm having is getting the part that you bolt the sprocket to off. Any ideas? It looks like it has some kind of snap ring under it too. Any help would be appreciated.
    83 Honda 250R (when it runs like its supposed to)
    85 Honda 350X - Just picked up 9JUL06. Needs alota work.
    Quote Originally Posted by cartmanchubs
    you have to crank it in twards the sprocket till you can get the snap ring off then turn it back out to take it off
