Thread: My 185s is acting wierd.
    leroy,ny
    245
    The plug is like a real white color that dont come off would this be because it is overheating or running too lean? It almost seems like its not getting enofe fuel.
    illinois
    743
    yep way too lean
    the valves are probably burnt like that as well
    is it a suzuk? does it have a inline fuel pump,check all the fuel lines
    Sep 2003
    El Paso Tx
    1,123
    Nah, its a Honda. You can probably look in the plug hole to see some of the valve edge and see if they ae not all curled up and thin on the edge which means you may need new ones.
    So many idiots that can't ride a motorcycle, so few hours to put my boot in their seat!
    Myeh heh heh heh heh!!!
    Columbiaville, MI.
    1,508
    Did this come on all a sudden or did you do some carb adjusting to it? Sounds like it is running lean I do agree,but what are the other symptoms? And most important did you do any adjustments to it? More info,please!!!
    MDR Racing
    LONG LIVE SANCHEZ RACING
    Tuscon,AZ
    77
    definatly lean....youve got some adjusment notches on the throttle piston needle valve.....put the c-clip on the very bottom notch.....if it pours black smoke its too rich...then keep adjusting it unitl it stops smoking when you rev it...idle smoke it normal....when you think you have it right look at your spark plug after its run for a while...you want like a dark cookie brown.....rich is always better than lean though
    tryin to get back on the map
    ex toys
    82 atc200 SOLD
    82 atc185s- In pieces in the desert somewhere
    83 atc185s- thrashed and left in texas somewhere
    83 atc110 in pieces in the desert somewhere
    83 trimoto 175- Clutch exploded and almost took off my foot
    1987 CBR600F hurricane- Parted and sold
    1982 Yamaha Seca 750- Sold
    1992 CBR600F2 thrashed and left in the junkyard to rot
    1994 CBR600F2 punched a mailbox, mailbox won...
    1997 Hyunai EGG....slower than my 110....donations please?
    leroy, new york
    1,025
    we replaced the carb, when puttin around it burns tan perfect. but when your ripping around like a bat out of hell, and running down the road at nearly WOT, it burns lean. We relised it was really low on oil, could that be the problem.
