Results 1 to 8 of 8
Thread: Having trouble
    Jul 2006
    Pocahontas, AR
    16
    Having trouble
    Can a trike smoke and burn oil and backfire alot and not have to be overhauled?
    Maryland
    3,078
    not typically. Sounds like you need piston and rings. rings at minumum but i I was doing it I'd go ahead and do new piston and get the vavles checked out.
    Oct 2005
    Pennsylvania
    863
    What Kind of Trike???
    2 Or 4 Stroke?
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Apr 2006
    Crestview, Florida
    2,429
    it can if its flooding severely. that would alow gas in the oil causing it to burn. but the smoke would smell like gas horribly. i dont see rings causing it to backfire . check your timing and carb.
    NE Arkansas
    2,344
    Quote Originally Posted by Unclediezel
    2 Or 4 Stroke?
    My old 200S.
    My Rags
    Lancaster, PA
    1,738
    The 200S is know for the slide needle wearing out and causing them to run rich and foul plugs.Raise the clip one notch on the needle to lower the needle into the seat more. It should be replaced if this is the problem but moving the clip will get you by.
    Welcome to the boards
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    NE Arkansas
    2,344
    We're gonna tear into it tonight and see what's going on.
    My Rags
    NE Arkansas
    2,344
    We're gonna put new rings in it. Everything in the motor looked really good.
    Will we need a ring compressing tool to re-install the cylinder over the new rings? This is my first rebuild, and don't wanna ruin anything, especially since the trike now belongs to Throesch! hehe
    The valves looked ok, but the exhaust valve looked the worse of the 2. It should clean up ok. Is this normal for the exhaust valve to have carbon build up on it? It was burning quite a bit of oil too.
    Travis
    My Rags
