kx tranny in a 86 t3
has anyone tried this? i have a 84 kx250 bottom and i was thinking of putting the tranny in my 86 t3. i have to split the case anyway to replace a left case seal. (i will do all bearings and seals). the output shaft is the same so all the gears on it should match up but the input shaft is different. i have not tore it down yet but i was looking for experience.
thanks
chris
i just compared the input shafts. the 86 has 10 plines for thew clutch hub while the kx has 6. the complet clutch baskets look like they would interchange.. so would this make more of a topend machine or low end??? wonder if i could just change out the 5th gear for a real tall 5th gear???
83 ATC70
85 ATC70
85 200x vintage racer
86 500r
Lots of parts
My 500R
//ArrowChat Integreation Code
