Thread: Smoking?
    cmracer15 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Smoking?
    My engine smokes very little when i fist start it up. But once it gets warmed it smokes my whole Dang block out..lol...its a whitish with a very slight blue sometimes. So im guessing its oil. the engine has been sitting for about 3 years and this is the first time its been started up since then. It has perfect compression..just smokes. Do you think its the ring? or do i just need to run it hard? is there anything i can mix with my gas to make it stop? thanks
    3 racing gokart's
    02 Kawasaki ultra 150 jetski
    02 kawasaki 1100 DI jetski
    Howdy's Avatar
    Celina, Ohio
    10,079
    I am assuming it's a 4 stroke here:
    My best guess would be the oil rings have gone bad. With it sitting for a while the valve seals could have went bad too. If you do a top end overhaul you willreplace the rings and valve seals.
    Mar 2003
    West Monroe, LA
    847
    thats souds right to me.
    May 2002
    Dublin, Georgia
    635
    That was my 200x a year ago.
    I did a topend job. No more smoke.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
