I am tearing down my 84 200x and have a few questions.
1. I am almost down to bare frame minus the engine, brake lines, front forks, rear axle and electrical wiring. What is the best way to disconnect the electrical? Should I try to get it off in one piece or is that even possible? The electrical scares me a lot.
2. Is there a direct replacement after-market shock for this bike? Mine is fine, but the previous owners were adjusting it with a and a screw-driver and its all chewed up on the adjuster nut.
3. My front wheel when spinning makes a ton of noise like the brake rotor is rubbing on the pads. My theory: Bent wheel, bent rotor, bad bearings....What do you guys think? I dont think its ever been wreked cause the forks and handle bars are fine, but who knows.
Thanks in advance.
