Thread: 85 250es big red accessory plug
    Aug 2006
    Tunkhannock Pa.
    29
    accessory plug 250 es big red
    Best way to hook up a cig lighter plug for spot light using the accessory plug from the headlight? Also, how to hook up a reverse light to come on with the dash indicator light ? Any ideas would be great , I just don't want to hack up the original wiring ... Thanks everyone
    Aug 2006
    Tunkhannock Pa.
    29
    What would be the best way to hook up a cig lighter to the accessory plug at the headlight for a hand held spotlight? Also any ideas on how to hook up a reverse light to work with the red indicator light on the dash? Any help would be great , thanks in advance ...
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    I would get a scotch lock and tap into the wire that goes to the reverse indicator,then run it back to a 3 dollar fog light relay, then to the light you want to light up.Hook up the relay like the package says.That way you dont hack into the wiring harness and you dont overload the circuit the reverse indicator runs on.You can pick up the stuff at autozone.
    85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
    Aug 2006
    Tunkhannock Pa.
    29
    thankyou for the replies , I"ll give it a shot ......sry for the double post , thought the first one didn't make it ...lol
    NE Arkansas
    2,344
    dufrain is right, hook up a relay. You could use a T-tap to splice into the reverse wire at the rear of the motor, I think the reverse wire in the wire on the left of the motor (?), that wire would be your turn on lead, then put the relay in the trunk with 12V power wire (remember to in-line fuse that wire) and ground, run a wire to your lights and you should be good to go. This is a great idea, I may do it myself.
    Travis
    My Rags
