Results 1 to 13 of 13
Thread: need help 225dx wiring
    Jul 2006
    iowa
    451
    hey guys, i have a yamaha 225dx parts trike missing a few things. the motor turns over but there is no spark. the wiring is a total mess and a few things are missing from it. i want to try to get it running. since the wiring is such a mess, i just want to hook up the esential things to get it running but im not for sure as to what i need and what i can do without. i dont need the electric start, headight, tail light, neutral indicator, and all the other stuff like that. all i need it to do is make a spark and have some sort of a killswitch hooked up.
    http://www.files.3wheelerworld.com/W...5DXKDXLDXN.jpg
    if you go to that link it is a wiring diagram for the 225dx. it would be really awesome if someone could quick save the diagram and open it up in paint and erase all of the wires and components i dont need. then post the picture of the modified diagram on this thread or send it to me in a private message. i know its kind of alot to do but it should only take you about 5 min. or so.
    Jul 2006
    iowa
    451
    any body? also, where is the coil located? i know mines missing, but where is it supposed to be?
    zoomerman's Avatar
    zoomerman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ontario, Canada
    351
    well if you follow the spark plug wire up to a small black thing with a ground and another wire going from it that is your coil
    1985 suzuki alt 185
    1985 honda atc 250sx
    1985 honda atc 200m (all apart)
    1984 honda atc 200es
    1984 honda atc 200x- need motor, plastics, axle, exhaust.
    1984 honda atc 125m- times 2
    1985 honda atc 200m all apart
    1983 honda atc 200e times 2
    1983 honda atc 250r-times 2
    1983 honda atc 200 4 parts
    1983 honda atc 110 times 3
    1979 honda atc 110 smokey
    1978 honda atc 90- restored
    Have lots of extra parts, if interested email at e_mcy@hotmail.com
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    I have the same trike, none of my electrical works, no lights no elec start, no nuturel switch, no key switch its all cut off at the ends. But mine still runs great, all i guess you have to do is follow your plug wire to your cdi box. Check that out and see if all goods. If you still dont have spark, then follow that all they way to your coil which is under your side case, check out that and see if your coil is good. After all that you should have spark, if not then you probably missed somthing. Also did you change your spark plug? Maybe get an electric meter and test everything.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Jul 2006
    iowa
    451
    my spark plug wire is gone too
    troy's Avatar
    troy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Canada
    254
    Quote Originally Posted by hondahaulic
    Look under the gas tank, yamaha likes to hide them there, also you will find your cdi...
    P.s rewiring isn't that hard, i had fun redoing mine, added a few extras in the process, such as a backup light that kicks in when i put it in reverse, hand warmers. had a horn at one time (but water made short work of it)...But if you want to go to the basics, your should only have 3 wires in the end, two for kill switch and one for the cdi (one or two for the cdi, can't remember) ..
    P.S.S when your get this wiring figured out , from the engine to the cdi and then to the coil and you still don't have any spark, i'm saying bad CDI or coil
    Jul 2006
    iowa
    451
    Quote Originally Posted by troy
    But if you want to go to the basics, your should only have 3 wires in the end, two for kill switch and one for the cdi (one or two for the cdi)
    um... what do you mean by that lol? which three wires and where do i hook them up?
    I modified the origional diagram and got this. does it look like it will work? if not, what else do i need? also, what other things can i remove or simplify?
    oh and by the way, can i use a coil from an older car? its alot bigger but will it work all the same? thanks for your help guys.
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    Coil from a car. Uhh no your local yamaha dealer should have it but they have to order it. I know there are a few people parting outs 225's on here and im sure one of them has a working one for cheap.
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Jul 2006
    iowa
    451
    ok. do you think i can borrow the coil from my honda 200s just to see if i can get it going?
    so does it look like my wiring diagram will work? oh and if you cand tell what some of the stuff on the diagram is, you should be able to figure out what the stuff is by looking at this linkhttp://www.files.3wheelerworld.com/W...5DXKDXLDXN.jpg
    Jul 2006
    iowa
    451
    oops my link didnt work. try this. http://www.files.3wheelerworld.com/W...5DXKDXLDXN.jpg
    Jul 2006
    iowa
    451
    so does anybody know if i can use my honda 200s coil on my 225 yamaha to see if i can get it running?
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    You will beable to hook it up. But im not sure if the volatge for the spark is the same so it might not run right. Post an add in the classifieds here, and im sure you will have a repsonse by tommrow morning. For cheap 2. probably like 15$/
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Jul 2006
    iowa
    451
    ok. i want to see if the motor will even run before i start buying stuff for it though. does anybody know if it can possibly damage my 200s coil if i try to use it? oh, and can you start a 225dx without a battery or with a completely dead battery?
