found this picture from a previous post but this is what mine should look like....
but I cant get the center axle bolt to unscrew... I've massaged it with aand wd40 but it still wont loosen up. I have two tools left in my arsenal that I know of... impact wrench or torch, or both...
any suggestions?
Also, the big castle nut on the rear axle is stuck too - Does that need to come off to access the drum or is it just the two smaller phillips head screws?
I'm kinda anxious to get my new tires, brakes and bearings put on there but of course these old parts don't want to come off for me without a fight.
Thanks
} and get some good penetrating oil/spray like Krol oil and fill that fr hub up around the shaft and bearings with it and let it sit over night and then you should be able to back it right out. works for me several times, becareful with too much extra leverage when trying to turn it out with a long pipe, definetly don't want to break it off and still have part of the shaft still in the hub
86-87 Tecate ROCK!
