Results 1 to 15 of 18
Thread: Douglas/ITP Wheel chart. Anyone got a link?
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    The one with the bolt patterns and stock sizes on it? Hook me up
    Jul 2006
    dennis kirk has one billy, im not home, I have a older dennis kirk catolog that has all atc's and quads in it the bolt patterns,ofsets in it, when i get back Iwill check
    NE Arkansas
    2,344
    here ya go, I can't repost the pic, so here's a link.
    http://www.3wheelerworldforums.com/s...ad.php?t=54615
    My Rags
    Live Oak, FL
    15,069
    Sweet TravEX, that was exactly what I ws looking for. Thanks!
    Charles Town, WV
    1,316
    Jul 2006
    so... wich quad wheel will be the closest? if its just alittle off, wouldnt a couple of washers, or grinding solve the problem?
    Live Oak, FL
    15,069
    Theres a Polaris front wheel that is pretty close (4x166 instead of 4x170) but thats to much to "make fit" I have a lead on a place that has teh 10in 4x170s IN STOCK that I'm gonna give a ring monday. If they dont have any or cant get any quicker then Douglas I'm going to see about just placing a large order of 10in no offset wheels and custom drill them myself...I'll have a few spares and if anyone else needs one I can hook them up too.
    Mar 2004
    North Central Ohio!!
    2,712
    The problem is that all of the quad front wheels are offset to protect the front brakes. Usually more than an inch. So that pretty much rules out any kind of spacer. Next you have the delima of having enough clearance to get the hub to fit. Mine was custom made and I still had to grind the hub and brake caliper. The other problem is that most quads run 5" front wheels and they are just too narrow. Just ask Virgil. His tire is major skinny and pushes.
    The best bet is the old Quad racer front wheels with the 4x166 pattern. Cut two in half, then weld the wide parts back together to make a nice rim. That's what Jason Hall did on his kids R. You'll still have some major fab to do.
    Live Oak, FL
    15,069
    Quote Originally Posted by 350Xhilaration
    Full list for Quads if you're interested.
    http://www.itptires.com/2006wheelchart.xls
    Rhuel, or anyone else with excell, could you print that to a .PDF for me? I dont have anything to open that file. Thanks
    Derrick, so you think the main issue is the offset instead of the drilling? That would make more sense on the cost and wait. Wouldn't take 5 minuts to drill the rim if you had a template setup for it. I'm gonna check out that one place I mentioned and if they dont have any I'm gonna give Douglas a call and see what they have or can do without waiting 3 months...
    Jul 2006
    true that, but good point the quads front wheels are skinny so you would have a skinnyer tire, and that wouldnt work that well hmmmm... whats the deal with putting a tri-z front wheel on? major mods or easy swap, becouse I'll pick up a tri-z setup tomoorow if thats the case...
    Live Oak, FL
    15,069
    Even less choice with the Z wheel. Not much in the x12 tire realm.
    Jul 2006
    how about this tire, It looks awesome for the front!
    any body try one
    http://zmperformance.com/?menu_dir=7...act_product=52
    Live Oak, FL
    15,069
    I located a place that can get a 10inch diameter 8inch wide Douglas wheel with no offset. I dont know what the bolt pattern is and dont care. I measured a couple rims I had up in the barn and 8inch looks to be wide to make work. Hopefully they can find something a little more narrow...
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    whats the big difference between 10 and 11 on rims anyway? handling wise.
    Live Oak, FL
    15,069
    With the same size front tire? Probably none or barely noticeable at best I guess.
