Thread: HELP! how to I remove the clutch nut? (Honda 200E)
    Nov 2002
    Kirkville, NY
    3,831
    OK, how to I remove the primary clutch nut on my 200E? I normally try to use a chisel on the dented part on the nut then just use the impact wrench to force it off but this one just won't come off. I doubt it has ever been off and I want to replace the clutch disks so it has to come off. Any advice?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Tionesta, PA
    5,747
    Electric or Air Impact wrench works well - I also think it is a reverse threaded nut.
    Jan 2005
    RI
    2,530
    the nut that holds on the centrifugal clutch is left handed. the one that holds on the clutch with the discs andplates is not according to the manual.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Nov 2002
    Kirkville, NY
    3,831
    Thanks, I got it after a a few more times of using the impact wrench.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
