Im taking my boyesen rad valve off and putting on some on that bad azz ESR reed cage. ESR wants 60 bucks for the boot. Seems a little pricey. What year CR250 intake fits the 250r the best and accepts the 38mm carb?
NDog
NDog
Of the CR250 intake boots that have the same bolt pattern & will fit, they are all angled too much, which causes the carburetor to stick out on the side of the bike. You will then have major issues trying to get the carb lined up with the airbox-to-carb boot.
THANK GOD somebody is taking THAT RAM......RAD THING OFF !!! i'll post the Part No. for the Boot Tommorrow ..."it's at work" Like Red Said .... it's BIG Enough for the BIG Carb's but ........ the Angle is MORE Toward's the Frame .. i use them on the TRX's....there shorter also ... Some Motor Builder's like when the Carb. is Closer to the Cyl.
"07" DR650 Suzuki Dual Sport
I used the factory carb boot for my 39mm. I just heated it up with a hair dryer first and slid the carb in. No problems yet, been in there a year.
I use them on my bikes 86-98 cr rad valve and a 1/2 spacer. it does angle the carb some more, I've never had a problem.
Rubber Boot Part No. 16221-KS7-830
"88" Reed Cage Assy Part No. "if needed " 14100-KS7-831
"small" Intake Gask. No. 14132-KAE-000
That's the ONLY Set up i ever use... NOT That other Mess !!![]()
Good Luck
UPP products makes a nice one that is cheap. Many colors too...
4 Strokes are NOT the wave of the future!
