Results 1 to 8 of 8
Thread: carb problems
    Jul 2006
    western ny
    3,366
    carb problems
    well i got my wire harness today so i got it put it. then i tryd to push start it and nothing exept gas poring out of the bottom over flow. what would cause this? also would that effect the starting of the three wheeler??
    GIT IT RAAAGGGGG !!!!
    Jul 2006
    western ny
    3,366
    ok i went out and messed around. i got it to stop leaking for 5 min. then it started leaking again. it sis starting to be a pain in the butt. please help me out. i tryd a diff float and still it leaks.
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    Try putting your float back to the original specs. Also is the seal on your float good? This what i do. Take the carb off, take the bottom half off, then flip it upside down so nothing falls out and everyhting in in place. Take the tube that goes to your tank (gas line) and blow in it while holding the float open. Your ganna hear your air comming out. Now close the float kinda firm not hard at all just enogh like the gas would close it, now can you blow thru it anynmore? If air is still going threw your seal is probably junk or somthing is backwards are wrong. If it stops clean t he heck out of the whole carb and put it back toghther right. Close it up and test it *Edited**Edited* you slap it back on your trike. If it doesent leak your good to go, if it still does you might need a rebuild kit.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    illinois
    743
    well take the carb off,drain the fuel
    take off the bowl, add a long piece of hose to the fuel inlet
    turn it upside down and blow through the long fuel hose .you should'nt be able to
    if you can - look at the needle and seat for ware-and replace it
    --if not,then the float height is probbably too high,and is allowing fuel to run out the over flow,adjust the floats
    yes this will flood the motor. if it is also going in the cylinder,and not shutting off the fuel like it is supposed to
    CLEAN THE CARB-it might be some old varnished gas in there
    Jul 2006
    western ny
    3,366
    i will try that tommarow and we eill see what happens
    Jul 2006
    western ny
    3,366
    well i did everything you guys said. the good news is i got all new jets and a clean carb. bad news is every time i put it back on the three wheeler it poors all over the freeking place. what could possably wrong with the danm freeking thing. im so pissed its not even funny.
    Jan 2005
    RI
    2,530
    it has to do withn your float needle. did you buy a rebuild kit? buy one if you didnt, they are cheap.
    it could also be the float seat. On most carbs they arent replaceable...im willing to bet its the needle tho...is it on your 200s?
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jul 2006
    western ny
    3,366
    ok well i cooled my nervs and it was the float. i needed to adjust my float it seems to be holding fuel so far.
    thank you guys for your help
