Results 1 to 15 of 23
Thread: drum brake
    Aug 2006
    hillsborough, new jersey
    47
    drum brake
    i know i ask alot of simple questions but im kind of new to trikes.well when my friend gave me his 250sx the rear wheels were already locked.i dont know how to unlock them. i tryed taking off the drum brake cover but i couldnt get it off all the way,i tryed to pry it of with 2 screwdrivers,is this the right way to take off the brake cover. is there some other reason why the breaks are locked,someone suggested if the pwer turned on it would unlock.is this true
    Pa.'s Highest City
    8,058
    Did you take out the two screws that are on the outside of the drum? They hold the drum to the hub. I guess It wouldn't hurt to disconnect the two brake cables off the backing plate as well. Oh, make sure your in neutral as well... never want to overlook the simple things you know.
    I took my SX drum off a few days ago. I was prying and prying as well. Then I figured I might as well take those screws out... came right off!
    http://www.3wheelerworldforums.com/a...1&d=1155151193
    Aug 2006
    47
    are you talking about the screws on the side that the cables are on or the side that the rim is on?
    Pa.'s Highest City
    8,058
    The screws on the outside of the drum. (on eitherside of the center hole) Let me see if I can find a pic....
    They would screw into the drum then the two holes on the hub (this is the best pic I have at the moment)
    Aug 2006
    47
    i havent gotten up to that part yet,i still cant get this cover off,are you sure you just have to pry.i have some pix of were im at.
    Pa.'s Highest City
    8,058
    Hmm...
    This is what mine looks like on the 85 250sx. I've never seen your setup before.
    By the looks of your pics I think you must take off the castle nut on the end of the axle and slide the hub off first.
    Got any pics of the rest of the trike?
    Aug 2006
    47
    mine is an 86,i gess they changed the brake assembly between the two years.do you by any chance know the size socket the castle nut is,i need to buy1.will i need a breaker bar to remove the castle nut or will a socket wrench work?. here are some pics of the trike...its a work in progress.look how bent the fork is
    Pa.'s Highest City
    8,058
    Quote Originally Posted by pavementking68
    Well.. I learn something new everyday...
    I can't really help you out on the proper size socket for that nut. I used a 1 1/8 inch standard socket and alot of heat. I didn't have the correct mm socket to fit.
    I'm sure someone around here can be more help than me....
    springville, PA
    6,185
    18mm castle nut. Take a rubber or plastic and beat the outside of the drum and then pry. Helps to break things loose. I didnt realize the difference betyween '85 and '86 either.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2006
    47
    i gess im going to try and pry it off again tomorro,and for the socket,will it fit on a regular socket wrench or do i need an extension
    springville, PA
    6,185
    regular socket. Might even try adjustables if you can't get the socket to work for some unknown reason
    Nate
    R.I.P HRR
    Aug 2006
    47
    if i was going to use an adjustable,the four bolts that the rim slides onto are in the way,is there a way i can take these off...
    Aug 2006
    47
    i just tryed putting a 21mm socket on the castle bolt and it was to small ,maybe a diffrent year has diffrent sizes???i think the right size could be 22mm 23mm or 24mm.
    Antioch,California
    149
    Chris20X,
    I n your picture in Post #4. Do you grease the big rubber seal at all? Mine had a ton of grease on it, I don't know if that is right or not???
    Inside of my brake drum was full of grease and dirt every where. Surprised the brakes worked.
    Also do you grease the pivot points on the brake shoes ???
    1986 Honda ATC 350X Stock
    1985 Honda ATC 250R Stock
    1985 Honda ATC 250SX Project Need Parts
    1983 Honda ATC 110 Rare Blue Model
    1982 Honda ATC 110 Front Brakes
    1983 Honda ATC 70 with Lights
    1979 Honda ATC 70
    http://autos.groups.yahoo.com/group/HondaATC/join
    Pa.'s Highest City
    8,058
    Quote Originally Posted by JackFlack
    Chris20X,
    Just clean everything up good with brake cleaner. Your seal may be shot like mine (from trying to pry it with a screwdriver)
