Results 1 to 14 of 14
Thread: Questions about water temp guage?
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    i have a billet water temp guage coming for my 86 R and im not quite sure where to install it. any help you can give me would be greatly appreciated
    wanta86r's Avatar
    Nov 2004
    mn
    385
    no one has ever put one of these on?
    Aug 2005
    Portland Or
    412
    I was wondering the same thing...somewhere easily visible but still reading at the most crutial temp area...Id imagine where the lines come out of the cylinder but its pretty tight around there. ???
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    wanta86r's Avatar
    Nov 2004
    mn
    385
    where are all of the r guys on this one?
    atcsteve's Avatar
    atcsteve is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    arizona
    157
    I have mine afrter the waterpump,about 2" up.Remember it(the temp) will drop quickly after you turn it off,but trying to read it while riding, to get a true reading,is hard to do.Mine drops about 20-30 degrees in a matter of 2 seconds,after i stop or turn off.Im not real sure of what temps are too hot,but mine never really gets over 210,and Ill shut it down over 220.Anyone know how hot is too hot?
    85 250r drag bike
    87 trx 250r ESR big bore
    Jan 2005
    RI
    2,530
    well water boils at 212...so the boiling point of the 50/50 mix is higher than that.
    i have no idea on an overheating temperature.
    i was looking into one of those esr ones...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    wanta86r's Avatar
    Nov 2004
    mn
    385
    Quote Originally Posted by atcsteve
    do you know if that is the ideal place for it to be located?
    on the hose comeing out of the head after the coolant has been through the head would be the ideal place.
    wanta86r's Avatar
    Nov 2004
    mn
    385
    Quote Originally Posted by bryan raffa
    i dont think it would be very easy to install or to read or install in that spot. any other suggestions
    i guess the your outer hose would be the only place you could
    Jul 2004
    miami, fl
    91
    I have the esr temp gauge om my R in the crossover hose between the two radiators. I look down thru the left shroud when stopped or idling around. it is about the only place you can see it with a clear view and not interfering with something. usually runs between 160-180
    Jan 2004
    NJ
    1,646
    I always wanted to install one but can't really see the benefit. The only time I can see using it is at warm up time. When I ride probobly one of the last things I'm thinking of is the water temp. If you have a cooling system failure while riding your engine is toast. Alot of good the temp. guage does you then. The hot setup in my opinion would be to install a analog thermocouple and have a temp guage mounted on your bars with a programable led over temp indicator. If you don't like a bulky guage mounted on your bars then a programable led would do.
    But really how many cooling system failures have you had? What can go wrong? Forgot to tighten the hose clamp? DUH. I don't think your going to blow a hose. And if you do steam will probobly come of the pipe. Radiators go bad-leaking. Impeller stuck.
    3 CR500R's and counting. Do I really need 4???
    Do I really need 9 Tigers?
    Laegers ATC500R
    DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
    Mar 2004
    Eastvale, CA
    630
    Quote Originally Posted by 88 Turbo Coupe
    Benefit #1 - They look cool (when visible)!
    Benefit #2 - 20% hp increase, guarenteed or your money back!
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    There is no good place on an R to mount them.
    You need to mount it where the cool water GOES IN to water pump or outlet that GOES INTO CYLINDER to get an accurate reading what water temp is like.
    Just buy some stick on temp strips and put them on radiator tanks and the cylinder jacket.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
