Results 1 to 13 of 13
Thread: OOPSY!! Dropped Piston Pin Clip into the Case!
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    well, it (the piston pin clip that is) got away from me when it came loose and shot down into the case.
    Well obvious you wouldnt want it down in there, so any easy way of getting it out?? Prefferably without splitting the rest of the case, would hate to end up replacing other stuff in it while i was in there and this is on the beater 200s ($50 special). What are the odds I can tip the lower end upside down and knock the clip loose??
    Whats the worst that It can do if i left it in there honestly (I know its a bad thing to do...)? Is the oil pickup inside the case large enough to suck it up?? Id imagine it woudl sink to the bottom much like the rest of the scum that builds up in the bottom of an oilpan.
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    i dropped a bolt into the top end one time. i just bought one of them antenna magnets at autozone for about a buck and got itm iout. maybe try that?
    Nov 2004
    Atlanta TX 3-states area
    1,592
    I have done the same thing on a 200s actually. I picked the engine up and carried outside, turned it upside down and started shaking it violently and after about 30 seconds it came out. I had to have someone watching for it or I would have never seen it though
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
    Oct 2005
    Pennsylvania
    863
    Yep....Pull the motor...
    BUT .... put it in a Plastic bag----Preferably clear... so if it does "SNEAK" out it wont bounce away....
    Also---drain the oil and leave the plug out overnight ..this will help avoid the clip "Sticking" to the sides of the case, or other internal parts.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
    Jan 2005
    RI
    2,530
    it cant be that strong of a clip...run the *Edited**Edited**Edited**Edited**Edited*!!!!
    actually shaking it will be the best bet...i might try a magnet first tho...
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2006
    Fort Wayne, IN
    88
    did the same thing on my 200x rebuild,i did the antenna magnet thing and it came right out in about a min. I had to bend it a little bit to get it around the crank and rod, just crank the rod with your hand and there was about three spots I could stick the magnet down into the case, Just kept sticking it down those spots and wiggling it around and pulling it back up to check to see if it was there, by the third time it came right out.
    yep I admit i have done it too! thos magnets are the bomb, a must have in the tool box!
    Aug 2005
    HI
    1,575
    I dropped the sucker in there as well once..i shook it up a little bit but I took the flywheel cover off and low and behold, it was right there stuck on the flywheel!
    Rest in peace Rex Carlson
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    Now for the cure... wrap a rag around the connecting rod when ever the top end is off. Murphy's Law, you know...
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Jun 2004
    potsdam ny
    1,227
    250ral must be one of the few with a slight amount of common sense. thanks al.
    smackkk's Avatar
    smackkk is offline Check my feedback before dealing with me. Arm chair racerNew to the board
    arkansas
    109
    well I say remove the engine and ssake the p-diddle out of it with a clear gallon bag over the thing. I have also filled them with 30 weight oil and got them out. You do want to get that thing out tho, I dropped one one time and was ring down the road and it got between the piston and the cylinder wall and siezed the engine up. Threw me over the handle bars and bummed me up pretty bad.
    Apr 2003
    HARTFORD CT, USA
    478
    get a magnet bra! We have all been there...thats too funny!
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Jan 2005
    Spruce Head Island, Maine
    893
    hes from maine, we dont have much common sense up here, try the antenna trick as long as the clip is magnetic, if you shake it out you might wanna do it over a concrete floor sos you can see it if it falls out, as long as all the oil is drained.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
