Results 1 to 15 of 18
Thread: A what is it worth question. 200X
    az
    2,003
    I talked to a lady whos got a 200X in her yard for sale, asking price is $275. I havent seen it yet actually may go look at it tommorrow, so I need some expert opinions here.
    she says the following, plastic is faded and has some cracks, seat is in need of recovering, no back tires or wheels on the trike, but she does have a couple in the yard I can have. I guess this is a mono shock? anyway the shock is broke so the back is just sitting there sagging. the good part is she claims the motor starts fine, and thinks its a 86 or a 85.
    64 dollar question. is it worth $275 dollars? Jim
    az
    2,003
    Last thing Im not buying it to part out. Ive always thought the 200X was a cool ATC, so if I get it I plan on putting it back together. Jim
    Jul 2006
    western ny
    3,366
    i wouldnt think 275.00 is a little high if it needs that much work. but i really dont know.
    GIT IT RAAAGGGGG !!!!
    springville, PA
    6,185
    tell her $200. I've seen ones sell for $500 that just needed a chain
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Sep 2005
    Northwest Ohio(Forest)
    974
    i would deffinatly pay it. I would prolly pay up to like 500 for it..
    IMO. Theyre good trikes!
    '86 200x
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    I would buy it too, well...it depends what you want from it, if you want it as just a rider to have fun on, buy it, who care if the plastic is faded, a shock shouldnt be that much, and if those tires and rims dont fit you can get some for cheap on here or on E-bay. If you are going to buy it to use as a show bike, it will cost alot by the sounds of it to fix and I would not go with it then. Make sure you get some if you go and have a look at it.
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    az
    2,003
    I think Im going to go with some cash, if it starts, great if not, I'll see how low she'll go. What kills me is I bought a 125M with a 200S front end on it 2 weeks ago for 200 bucks. And what Ive always wanted was a 200X I just never found one cheap enough. I it would be better to find a complete driver, but I can alway buy parts little by little. and I think the rear wheels on the 125 I have has hubs with the same bolt pattern so I maybe able to borrow the wheels I already have. Jim
    Columbia
    5,131
    I would low-ball her, worst case senario, you have to throw about $200-300 into putting her back together. If it is what she says, then you would end up with a totally decent $500 200x.
    I would be all over it.
    Good luck.
    na
    5,702
    if it is a 86 model,pay it and go home happy. if it is a 85 try to get it for 175.00.the way to tell, is the swingarms are way different.the 86 model has a eccentric carrier for adjusting the chain,like a 300ex 400ex 250r. the 85 has the chain adjustment at the swingarm bolt.there were 2 little dirtbike adjusters in the frame to move the swingarm back and forth to get the chain adjusted. there were many other differences too,but that is the easiest to see. the 85 was not a bad trike,but the 86 and 87 200x was way better all around.ohh yeah. the 85 has a round tube frame. the 86-87 200x had a square tube frame.the 86 87 was better and worth more money.
    Proudly NOT a member of
    "Team on the Teat"
    az
    2,003
    Well I went ahead and took the plunge I think its a 83 model with the serial number JH3TB0522DC288XXX the seats ripped plastic is cracked some, and faded, rear hub is missing one of the castle nut. back tires are bald and flat, has a super trapp muffler on it. front brake master cyl. res. is cracked. rear brake works,worse part is the back shock where the rod goes into the mounting bracket broke I think I can rethread it and install it. the motor does fire right up and no smoke. when you kick start it, its feels like its got alot of compression. ended up paying $250 for it, I didn't have the heart to try to lowball her. Jim
    Sep 2005
    974
    cool! get up some pics!!!!
    '86 200x
    az
    2,003
    heres a couple of pictures sorry about the grainy photos I just figured out how to resize photos and resized them alittle too grainy. Jim
    na
    5,702
    hey a little elbow grease and you will have a nice 200x.good find
    "Team on the Teat"
    Sep 2005
    769
    Awsome deal, I cant wait to get my quad sold and buy something just like that. I want something that is cheap, needs work, and in the end will be a trike and under $700.
    Current Rides
    smackkk's Avatar
    smackkk is offline Check my feedback before dealing with me. Arm chair racerNew to the board
    arkansas
    109
    that looks like a 1985 model to me ?
