yeah, the one from deepa
My manual says the gap should be .015 to .025. I set mine at .020 . Loosen the 2 screws securing the box, and put your feeler gauge in there and tighten em up. As for the valves, .05 intake and .06 exhaust. Loosen the 10mm nut up (with motor at TDC and cam lobes down), and take a flat head screwdriver and the feeler gauge under the tappet on top of the valve. When you tighten the 10mm nut back, remember to hold the tappet in place with the screwdriver, cause it tends to tighten down with it. Hope it helps.
Travis
My Rags
Is there any one in ohio, that could help me. I want to have this thing running!!!
This magnent that spins...with the motor off, are you supposed to be able to turn it with your finger? I am going through the same ignition problems on my 82 200x. To those w/o feeler gauges....will a credit card work to set the gap?
My timing is off one tooth and I can't get it right on, it jumps either one tooth the other way or more teeth off.
I still have no spark. I'm looking over the wiring harness now, trying to see if there's anything messed up, from when I took the engine out. Could it be a bad ground???
Can I use paper as feeler gauges? I am determined to get this thing to spark, I am saving up for a lifen right now. but I can't wait forever to ride this beast.
Originally Posted by Aka_am
make sure you are tdc (top dead center) then line it up.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
I've tried..It just doesn't want to be lined up right, being off one tooth won't make it spark will it?
If you have no spark or weak spark its almost always the stator.
savin one atc at a time
wow its been awhile since ive been on here..and guess what...im having the same problem with my 82 185s..timing is correct, air gap on the pulse coil is right, valves are set right, 10.5:1 piston brand new with brand new rings and fresh hone job, ngk dr8es-l plug and all wiring and coil and cdi box and everything else is hooked up right, also a brand new stator coil...i had it runnin for about 15 seconds behind my truck and then it died and will no longer get spark....sounds like the same scenario to me, its getting fuel cause the plug is wet when i took it out....but my pullstart cord broke, i and it wouldnt recoil either and it also has a brand new spring, pawls and the little springs and all...wierd...anyway im having the exact same problem with my 185s
trikes owned:
85' 200m - sold
84' 200x - sold
83' 185s - sold
82' 185s - sold
85' 350x !!! - selling
