Results 1 to 15 of 26
Thread: rear end mods on your tri z, wheels tyres ??
    Oct 2005
    uk
    87
    just a little thread for all you lot to show off your rear ends ( PLEASE PICS ONLY OF YOUR WHEELS TYRES)
    my tri z 1986 model
    I WAS LOOKIN AT MY TRI Z THE OTHER DAY. and it must have the original wheels tyres on it.......BIG FAT BALLON THINGS. i think this thing could float on water if i tried?
    i want to change to a bigger wheel and a low pro tyre, or flatter looking tyre.
    so with some pics from you guys and detailed info . what wheels , tyres hubs and so on .
    this will be a good place to show off your wheels and give other ppl some info on what to put on there tri z,s
    thanks again ian.
    heres a pic of my tri....just to show u what i mean.
    Oct 2005
    uk
    87
    error on loadin pic .......will try later ?
    Nov 2002
    Victor NY
    538
    I run 20 in holeshots on mine.....on itp rims
    Oct 2005
    uk
    87
    any pics ??
    i want some ideas for my 1
    Northern CA
    1,104
    Just run some of these and you Should be ok....
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    Oct 2005
    uk
    87
    hahah rubber and studs........who told u about my fetish ?
    Front royal, va
    2,186
    i use many different ones, i now use yzf450 tires and factory 9 inch wheels, also i run turf tamers on 10 inch rims, i tried them 44 inch tires but they wouldnt clear the rear fenders (or the footpegs)
    Attached Thumbnails Attached Thumbnails mid_31-089F4E44FC8D469D8D779804E004D8FE.jpg
    Aug 2006
    new hampshire
    914
    if you flip the stock wheels around i think you gain just over an inch. valve stems also will be a little more protected from side ways action!
    Las Vegas, NV.
    2,493
    Iwallace, since you haven't gotten a straight answer or pictures yet from any of the Tri-Z guys yet, I guess an old reliable Honda 250R guy will have to come to the rescue. Even though it's a Honda, you can still get the same tires for your Z. These are 18x11x10 (18" diameter x 11" wide x 10" wheel) Fast Trekkers. I would then recommend either an ITP or Douglass 10x8 rear wheel, with 3+5 offset, to mount them on, and I haven't heard of any difficulty getting those wheels in your bolt pattern (4 on 115mm I believe). I don't have a pic of them, but 18 or 19x11x10 Holeshots are also very popular low profile rear tire choices.
    With either set of tires, you'll love how the bike handles. The ride will be a bit stiffer, because you no longer have those big balloon tires soaking up the bumps, but the improved looks, handling, and ability to confidently pitch it sideways at a moments notice will more than make up for it.
    May 2003
    Houston, Texas
    2,409
    Red Rider,
    Shouldn't those hooks be facing the other way?
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Ontario, CANADA
    4,538
    Hey, Im using the razrs on both my Z's and I love em.
    Here ya go-
    There ya go!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Las Vegas, NV.
    2,493
    Quote Originally Posted by Darius1502
    On my first set of Fast Trekkers, I did have them facing the other way, and they had no directional arrows. Now the manufacturer puts directional arrows on them, and they are mounted up properly. Seems backwards though doesn't it?
    na
    5,702
    i run a titan 489 23 inch on the front. i want to go with a 22 inch up there next time.the rears, i run 18 inch holeshots on 9 inch offset rims on honda 250x hubs.this set-up gives you 50 inches of width in the rear.
    Proudly NOT a member of
    "Team on the Teat"
    Las Vegas, NV.
    2,493
    Now we're getting some responses from the Tri-Z guys. From the way that the Z owners are responding, early-mid afternoon, I can tell that those with flattrack tires are party animals, and are just now getting up after a long night of partying. And those that get up earlier are wiseguys.
    na
    5,702
    Quote Originally Posted by Red Rider
    how did you know i was up all night??lol. i was tore up from the floor up.
    "Team on the Teat"
