Thread: New battery won't hold a charge?
    Pa.'s Highest City
    8,058
    I got this brand new battery a few months back and I only get maybe 3 or 4 starts out it. After that I just get a click and that's it. The quad does start right up with the pull starter so I just left it go at that. But I really think it's time to get this straightened out. Any ideas?
    NE Arkansas
    2,344
    Is something drawing off of the battery when the switch is off? Disconnect it between rides and see if it holds charge. That would suck if that's all you got out of the battery! Any warranty on the battery, if it turns out to be bad?
    My Rags
    Mar 2005
    ma
    988
    a click means the battery is low. you must have a draw somewhere. even if it wasn't charging the battery should get more than 4 starts. check to see if the battery is charging when the quad is running. you need an ohm meter
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Pa.'s Highest City
    8,058
    Well believe this or not I found the problem. Shawn I switched out that seleniod you gave me and it still clicked. I then took the rubber boot off the starter and seen the connection was corroded with rust. Ckeaned that up now it fires right up everytime.
    No more pullin my arms outta the socket!!!
