Thread: 86 200X ext. axle ques.
    DIGGER DOG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    in the sticks s.w ga
    446
    Ive just aquired an 86 200 X all stock and im looking into getting a +4 axle for it
    I went to durablue website and they list one for 85 but cant find anything for 86
    anyone running an extended axle for an 86 ??? or know what might work .
    83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
    Jun 2003
    englishtown NJ
    2,676
    a 83/84 250r axle will work, a stock 83/84 250r axle is the same as a +4 86 200x. You will have to use a 83/84r sprocket(expensive to get in a 38t) and you will have to file down the carrier on the chain adjsut edges some. I use a +4 83/84 250r axle in my 86 200x. Everything works, but the rear sprocket and you need 83/84r axle nuts. If you do go to a +4 83/84r, get 83-85 200x or 83/84r hubs, as the 86/87 hubs are offset and you will be too wide(about 53")
    446
    Awesome deathman thanks ,for the 83-84 +4 R axle would i still need to file the edges of carrier the same as the stock R axle ?
    Jun 2003
    englishtown NJ
    2,676
    yeah, its not much at all. I think you can use 83/84r carrier to aviod the whole problem. Just be aware that you have to use the sprocket bolts, axle nuts, sprocket. I would get a whole setup(even if the axke is bent, so you have all the parts) and then get the +4 axle and transfer the parts to that. Everything about the 200x rear brakes work. Also you would have to get a 38t(or smaller) sprocket and those are only custom made, sprocket specilties and sidewider sell sprockets that are in the correct tooth count. I don't like sprocket specilties, mine wore out in about 8 hours or riding(about $80), I have about 40 hours on my sidewinder sprocket wilth little wear, but the sidewinder sprocket cost about $120 and was well worth it. It will cost you some money to do the conversion to a 84r axle, but in the end its well worth it.
    baisically $500 for the extended axle, figure about $100 for the complete rear end(for the hubs, sprocket bolts, axle nuts and axle end nuts), $120 for the sprocket.
