Results 16 to 30 of 31
Thread: Real dumb 200X question
    I use the clutch most of the time. But, if I'm trying to power out of a turn and I'm at an awkward position or I'm racing standing up, I don't use it.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Always use the cluth.
    DON"T BE LAZY..save your clutch.
    Is it good to use engine breaking to slow down on a two stroke?
    Aug 2007
    Moab, UT
    1,807
    I always use my clutch, upshifting or downshifting. I've been into way to many motors that have excess tranny wear or bent forks because of not using the clutch. Besides, it's much cheaper to replace clutch disks. As far as using engine braking to slow down on a two stroke. I personally try not to. People can disagree with me if they want but I don't think the engine gets enough lubrication if you do this. Think about it, the engine is suddenly spinning at high rpm but is only drawing fuel from the idle circuit of the carb, hence not much oil. I don't know, maybe I'm paranoid.
    Lancaster, PA
    1,738
    I do not always use the clutch BUT... you should. I will recommend that you use the clutch when down shifting (I do) and to let off the gas when upshifting so you are not "speedshifting". It could bend a shift fork.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Ya know what?? I am yet to find a bent shift fork..... All I ever find is worn or rounded lugs/dogs on the gears and the shift mechanism on the drum gets rounded also in beat motors. I do "think" that letting off the gas when upshifting is a good thing and about the same thing a clutch does.
    EDIT - I CANNOT do a long distance wheelie if I use the clutch, I have to upshift clutchless......
    Sep 2007
    it is called speed shifting it is easy to go up in gears but it is harder to down shift how u do a long as wheelie with out droping the front
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Quote Originally Posted by edog View Post
    It aint gonna hurt your clutch, it's gonna put the wear directly on your tranny. The reasons truckers do thid is because most rigs run an unsynchronized trans, meaning you haven to double clutch to get your gears to spin appropriatly to mesh.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Columbia
    5,131
    Revmatching. I dont use clutch on my bikes unless im puttin.
    You dont have time to clutch in a race.
    Sep 2007
    oregon
    2,292
    this is stupid, if there is a cluch on a bike it is supposed to be used, if there is a clutch in a car you use it, imagine driving a car that has a clutch and not using it...
    Sep 2007
    oregon
    2,292
    and the reason they don't have to use the clutch in a race is that they don't care and they can replace the motor after each race....
    [QUOTE=factoryX;549140]this is stupid, if there is a cluch on a bike it is supposed to be used, if there is a clutch in a car you use it, imagine driving a car that has a clutch and not using it...[/QUOTE
    No, it's not stupid.....
    Yes, factory racers get free parts so they beat the snot out of everything to win a race.
    You cannot compare an automobile to a motorcycle transmission. The engagement and locking mechanism are completely different. Most auto trannies have helical cut gears with synchros which is nothing like an ATC or MX tranny.
    I will agree that using the clutch will lessen the wear on some transmission parts but I do not believe it is an absolute essential when shifting. However, you need to let off the gas a bit when shifting to avoid binding. All your really doing is allowing the gears to relax a bit so they can mesh with the mating adjacent gear, thats all folks....
    To each his own.... But, lets race? You use your clutch and I won't. I can go so much faster without using the clutch and I probably use it 50% or less of the time. I've been riding for 25 years and I have never stripped a gear or bent a shifting fork and have ridden the same way since I learned to ride. Or in the case of a long distance wheelie, if you pull in the clutch you lose the drive from the engine and the front end drops. Then most people overcompensate and give it too much gas to get it back up again. I yank it up in 2nd, back off a bit and run through the gears without the clutch.
    The only damage I have found was on machines I didn't ruin myself. That damage was from power shifting (not letting off the gas) or popping out of gear because a thrust washer was missing or something wasn't assembled correctly.
    Aug 2007
    Pa
    108
    Why would'nt you use it?
    Columbia
    5,131
    I dont use it unless Im starting or stopping, or going real slow. It wont break the bike if you rev match- this is where you let off the gas to where you match the next gear, you wont hear a CLANK if you do it right. You dont just throw it into the next gear.
    Like I said, If Im just cruizing, or taking it easy, I clutch. If Im ALL out gettin it on, I rev match. My tranny looks just fine. And to hear these guys that have been riding and racing for years without issue, I am confident I will not change my riding style.
    toyvette81 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    durham
    284
    of course you should use the clutch, just like anything that comes manual, car,truck,motorcycle, or w/e its there to shift with..
    now lots of people do it with no clutch but thats mainly for drag racing, if you dont clutch, it its a guarantee that it will wear the components out faster, and thats on any trans. there is a magic point on anything though where it falls right into gear with no problems or stress but its impossible to hit that certian rpm everytime.
    1981 Corvette (chevy bright white)
    1998 GMC shortbed step side lifted,35's,mickey t's
    1995 Monte Carlo (gas mileagle car)
    1987 XR100
    1989 Polaris Trail Boss 250 (old reliable/faithful)
    1984 ATC 110 (Blue)
    1985 ATC 350x (DG exhaust)
    1986 ATC 250r cleannnnnnnn
    2002 polaris scrambler 500HO 4x4 (supertrapp exhaust)
    75 jeep cj5 6" lift, 35" procomps, locked up,
    77 jeep cj5 3" lift, 34" tsl's
    67 jeep comanche(running soon)
  15. #30
    Sep 2007
    Hawley MN
    144
    i race, and race hard. ive ran alot of machines and never had one problem from a trans from not using a clutch. i mean i still use it alot of the times but somtimes i just dont. im not jamming the gears or anything just getting the rpm's right and pop it into gear. atc's and bikes such as race models like a 250r or crf 450r have better trany's that can stand that abuse better. im not saying its good but its not the end of the world and i have never ever had a problem with it. i dont see why people think its so bad to not use the clutch all the time?
