Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: swingarm bolt!!!!!
    Aug 2002
    New York
    1,098
    man oh man...good luck. I too cut both of mine out with a saws all. It's one of the chronic R problems. When you finally put it back together....lots of antiseize and take it apart every couple years to make sure it still comes apart. Good luck. It's a pain. I hope yours comes out easily.
    May 2005
    Southern NH
    1,489
    Quote Originally Posted by ChrisD
    wow, coming from somebody like you that just really say's it all Like I said I'll try an impact gun and pray!!!! After that it looks like I'll have to get creative.........
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Pennsylvannia
    1,147
    Use an impact wrench. When I got my BEAT, rusty, POS 350X to restore I was like "Wow these bolts are going to be a beotch to get out, especially the big ones".. but an impact wrench took them right out. I tried and tried and tried to get the shock mount bolt and the swinger bolt out and then I saw the impact wrench sitting there on the shelf, and it was like a message from God.. "Use it!!!" lol.. so I did and it popped right out.
    May 2005
    Southern NH
    1,489
    hopefully that's what happens for me!!! I will pray long and hard tonight hahahaha
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    I had to beat the snot out of mine to get it out on my R. I had it down to the frame.
    I used quite a bit of PB Blaster, and soak time. Then I got the 5 lb sledge out and beat the tar out of the bolt till it came out. I then used an old socket extension to force it out the rest of the way. You WILL destroy the bolt. I tried putting the nut on loose, hoping not to damage the threads, but no such luck. When it was finally out, I looked and noticed it was rusted heavily in place, and grooved at the spacers.
    Definitely get the bushings from x.system. They are awesome. Just be careful installing them so you don't damage the ends of them. Grease up a new axle, slide it home, and never have to swear at the swingarm bolt, or bearings ever again. Hope you have an easier time with bolt than I did. I learned some new words when I worked on mine
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Aug 2003
    Reno
    203
    Ok, I've been thru this one
    I can tell you what worked for me.
    I used a rivet gun with a soft piece of aluminum to protect the end of the bolt.
    Use the vibrations of the rivet gun to drive it back and forth just a tiny bit each way.
    Soon the corrosion will loosen an it will come out.
    Good luck.
    Earnest Hemingway:
    "Motor Racing, Mountain Climbing and Bull Fighting are the only true sports.
    All the rest are children's games played by adults."
