OK with the powervalve assembly in the 86 Tecate. Is there anything past the 4 base bolts and the left hand threaded actuator lever that needs to be removed?
This is to get the cylinder off.
The actuator moves back and forth correctly from what i see. Just want to make sure there is nothing hidden in the jug there before i tap with a rubber mallet to remove.
Thanks in advance.
