i just got a 1983 185s that was sitting for 19 years in a guys garage. it fired rite up without cleaning the carb it smoked at 1st till rings set up or whatever you call it. the carb should be okay on this 200s. i had to buy a filter for mine i went to remove it to see if it was okay and the filter just crumbled away. that 200s dont seem like a bad deal if it dont go much higher.
the 185 i got had the original tires that are like 95% tread a hondaline rack and hitch. it has the original bars and brake levers and grips. i got it for $250
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
