Thread: Yamaha 225DX Automatic Clutch Question.
    Aug 2006
    NEBRASKA
    9
    Mine seems to slip a lot when I take off, is there any adjustment for this? Is there any where to get a service manuel for this trike for I would have to ask all these dumb questions.............? What type of oil do I run in the crank case also. Thanks for all your help
    Aug 2006
    NEBRASKA
    9
    springville, PA
    6,185
    yes on the side of your engine (should be the right side) there will be a nut threaded on a bolt with a flat head screw driver tip. hold the bolt with a screw driver while you loosen the bolt, then turn the bolt clockwise till you hit resistance (go nice and slow), once resistance is felt turn back 1/8 of a turn and tighten the nut down.
    10w30 in winter, 10w40 in the summer but I have even run 20w40 and had no problems. I also only run fully synthetic.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Here you go.As for the oil,thicker in the summer,thiner in the winter.
    Aug 2006
    NEBRASKA
    9
    Thanks, I'll give it a shot. If this doesn't work, is it suck to change the clutch's out?
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    The only problem I see is the screws that hold the side cover on.The can
    become seized in where they thread into the other case half.I had to use a
    pair of channel locks on the heads.This didn't work on all of them.I snapped a
    few of the heads off.Once you take the case off you can get to the rest of the
    screws with the heads snapped off.Just put on the channel locks of the shaft
    off the screw.Remember....righty tighty,lefty lucie.
