UPS droped off a set of fork's i bought - off of a 1985 ATC 250R
Problem is when i compress them they get stuck going down & they don't go down smooth ... they stick.
they do have fluid in them , no leaks .
What could be the problem ???![]()
I would check to make sure they arent bent. Run your finger along the top part to see if there is any scaring on the surface. Springs could be bad too.
86-87 Tecate ROCK!
how can you check if the springs are bad ?
if they stick down they are probably bent
you need to take them apart and roll the sliders on a flat surface and see how they are.
both my 350x and 250r fork sliders arebent, but they dont impede the operation of them
mike
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
Mine compress down but only come up half way...never thought about checking to see if they are bent.
I just removed a set off my 250r to put some new ones on. If you are needing another set I am sure I could part with my other ones and I know they are good lol.
86-87 Tecate ROCK!
I inspected the forks last night and their not bent ...
they have fluid , seals are good .
you took the forks apart and the silders roll evenly on cement?
mike
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
i have them here at work now ... just looking at them they straight .
i am going to take them apart now... i got 2 1/2 hours to work on them.
What should i look for ?
How much man?Originally Posted by ScottZJ
you cant tell by just looking at them.
remove the top caps and drain the fluids and pull out the springs
remove the dust seal cap and then the snap ring then fork seal
remove the allen bolt on the underside of the forks
lightly pull up on the slider over and over again to bang/pull the fork seals out.
remove teh dampening rod from teh bottom slider holder.
not too hard to take them apart.
while they are apart definately put new fork seals and dust caps...a set is like 30 bucks at service honda.
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
Shoot me a PM and lets talk.Originally Posted by Fox250R
86-87 Tecate ROCK!
I am going to inspect them now , Drain fluid and it's bad looks like water and oil mix.
i bought 1 quart of - AMSOIL -Shock Therapy / Light #5 , For shock and forks
How Much FLuid in each shock ? ? ?![]()
Did i get the Correct Fluid ? ?![]()
