Thread: Installed a K&N filter on the - '85 Tri Z 250 ATC ... Problems
    Oregon
    2,471
    Nothing but problem's with my ATC's i got ...
    Well i order a K&N Filter and Outerwear PRe-filter for the Tri Z 250 '85 .... look's nice.
    Removed the Old STOCK Filter ( full of oil ) and Installed the K&N Filter with outer wear pre-filter ...
    Started up fine but Doesn't Run the same ... Mid to Full throttle just doesn't Pull any more on all gears ...
    I check on the needle clip it was at it's highest setting 5 ... but it ran good with the OLD Oily FILTER .
    so i changed the needle clip to 3 middle setting and now it kinda pop's but it did help .
    it has a PIPE on it DG Performance , Running 92 octane and mix at 32.1 on HP2 Honda oil synthetic 100% .
    Should i go up in jetting ?
    or can i just Adjust it with the needle clip position ?
    Phoenix, AZ.
    6,719
    Going to a new K&N versus an old, soiled OEM one, you're flowing way more air now and need to richen up your jetting across the board.
    Mar 2004
    Eastvale, CA
    630
    What said, plus calling a Tri-Z an ATC doesn't help either. ATC's are made by Honda (the best) and Tri-Z's by Yamaha.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Jan 2004
    Palmetto,Florida
    2,300
    DANG HONDA'S Patented the word........"ATC" !!!!
    That's why "all the rest" are ............... ATV's ......
    "07" DR650 Suzuki Dual Sport
    Oregon
    2,471
    Hey true on that , i have 1 tri z and 2 atc's 250R ...
    Still a rookie here ...
    Nov 2002
    Kirkville, NY
    3,831
    hey it has honda blood (oil) running through it = ATC
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
