hi, wanted to change the oil on my 1983 250r. what grade oild is best? looked in the service manual which said 10w 40. which is the same as what i use in my car, is that right? what is a good make to get to?
thanks.
rob
england
thanks.
rob
england
That is correct. 10/40 motor oil.
I use the Valvoline or Castrol 10/40.
Don't put in synthetic though or you risk clutch slippage.
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
ok cool thanks for the fast replie
CORRECT !!!! 10-40 in the Winter and STRAIGHT 50 wt. "or 20-50" in the Summer
KENDALL or Valvoline................................ !!!!!!!!!!!!!!!!!!!!![]()
"07" DR650 Suzuki Dual Sport
anyone here ever use rotella oil i do and it works great and is fully synthetic and i have yet to feel any clutch slip in any machine ive run it in from my 250r to my bros 660 raptor. and best of all its fairly inexpensive.
83 250R![]()
91 CR125R![]()
am i reading this right?
ya'll put motor oil in your tranny?![]()
ever here of Bel-Ray gear saver?
it's made for the bottom end of these motors.![]()
84 250R (sold)
85 250R 38mm Keihin PJ,Rad valve(w/spacer),
CR250 head gasket,all DG exhaust ,
13/37 gearing w/ 22-11x9 wooly booger type treads,
head re-chambering and +6 swinger by Ronnie,
stock jug and bottom end,
112 octane race gas w/ klotz R50 @ 32:1
There are 2 different Rotella oils available. A synthetic 5w-40 and non-synthtic 15w-40. Both are very good oils, and are actually rated for motorcycle/atv wet clutch applications. I run Rotella in most of my machines with great results.Originally Posted by willcamach
Also there is the standby ATF type F for exteme use in 2 stroke gearboxes.
Remove all the warning label and let nature take its course
Yeah. Manufacture made the bike. They should know. Plus on my R, the gear oil is changed every other ride so I am not throwing money away on bel ray.Originally Posted by don250r
1980 110
1982 250R
1985 200s
1985 250R
1985 350X
Parting out...
1983 250R
1984 185s
PM me for parts
Originally Posted by crackshot
Isnt that a bit of overkill to change the oil that fast.
85 Tri-Z "Rumble Bee"
85 250R "Red Rocket"
83 200X "Flat Tracker"
I change mine about every 6-8 rides. Depends if im busy, or how long the rides are.
RPFLU member and co-owner.
Hardtails is all we do.
#NOLINK
#MAKEHARDTAILSGREATAGAIN
#SUSPENDTHIS
If you use regular oil,you should change it all the time!Get some gear saver,and be safe,this stuff is great and breaks down way slower than the others!!The way I can tell its better, is if you put fresh regular oil in,ride it 1 day,then change it,it will look like water.If you do the same with gear saver,it's still like it should be!!
85 250r drag bike
87 trx 250r ESR big bore
well i just run honda hp.specifically made for the 250r.sounded like a good idea to me.made by honda,for my honda,hmm,they maybe on to something.
I think that would be my second choice for sure!Its been proven on the tracks,and that says alot!!
85 250r drag bike
yeap,i love it.i recently switched form maxima mtl 50 wt.this stuff is amazing.leave it to honda to make the best....again
duh, wtf are you guys on? use 80 or 90 wt gear oil. honda makes tranny oil that is 90 wt specifically for 250r's and cr dirtbikes, they come in the liter bottles at the dealer, other than that you can just get some decent 80 or 90 wt gear oil. that is what is supposed to be run in a GEARBOX, not a whole motor, which motor oil is used for.
