Results 1 to 3 of 3
Thread: big red rear shock!
    87250es's Avatar
    87250es is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    south east texas
    283
    Angry big red rear shock!
    i want to take the big red rear shock apart to blast it and powder coat it but i was told that you could not, and i see no way to do it either any suggestions or other models that i can still buy the rear shock for that will work
    87 ATC 250es
    86 Polaris Scrambler
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    The shock will come apart. I have done it. Took the spring off and repainted it. Its not that tough, but the spring is under quite a bit of tension. Isn't easy, but it can be done. Now I dont konw about the shock itself. But you can take the spring off.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    87250es's Avatar
    Apr 2006
    south east texas
    283
    thanks clay. i can use a coil spring compresser to remove the spring. i wanted to powder coat the shock and rebuild it but i do not se any way to refill it with gas or oil after the fact. so i quess i will just paint it. i may be wrong but i think i asked you a while back what kind of paint that you used to repaint your big red tank. i know you answered me but i lost that email. i bought 6 different kinds od red powder to do the tank but none of them are even close.. i know the factory paing is PPG Passion red but, the local ppg shop here can not find a paint code off of just the name. thanks for any information
    87 ATC 250es
