I finally got my rubber "unplugged" honda manifold from ESR today so I yank the old boyesen RAD valve off and put the spacer under the reed cage. I really wanted to put it ontop because I already have tons of low end but we will see.
Anyway, having some problems getting the airboot to pull toward the manifold enough to be secure. I didnt realize how long the boyesen was. I have had the 38 striker on for months but now am comming up short on length with the slightly different angle and length of the ESR stuff. I am dying to see if they hype is true but cant stretch far enough to keep this stuff tight. I could probably do it but im sure after a few runs with vibration and bumps it would pull apart. ANY IDEAS?
Second, any comments on reed spacer placement? Normally its for moving power lower but if you put the spacer inbetween intake and reeds would this increase top end?
Last, Ive had a moose head gasket on ever since I got my top end back from Port and Polish. I used copper spray and torqued to spec and torqued again after a few days but have always had moisture along the left half of the head gasket. I have ridden it a lot over the last few weeks and every time there is fluid along the head gasket. Its not much and doesnt drip and my coolant level hasnt dropped significantly but it bugs me and I wonder what is going on.
I have a brand new OEM honda metal head gasket. Is it worth the trouble of changing for just a slight bit of moisture? If its not coolant what the hell is it? I have been unable to get a dry crisp tan jet. They are still a little wet looking even with a 170 main and airbox off.
Thanks guyz
Ndog
on it daily. also, if your running all of this performance stuff, just take you airbox out, save some weight and run a k&n with an outerwears on it. works great, and the outerwears keeps water out, trust me on that, lol....
